Printrbot Talk Forum • View topic - Plexus's Kisslicer settings
Postby plexus » 2013-Dec-Mon-20-Dec
I thought I'd share my settings with the community. I have various nozzle and layer height sizes. I use µm for layers. 100µm = 0.1mm Also are my material settings for a bunch of different materials. Really these are just temp settings although there are retraction and wipe tweeks in some of the other materials that ooze a bit more. Also are my pre/post g-code. you will have to put in your own calibration numbers, accelerations, PID etc. I also have my bed settings in this for my printrbot+ so again you'll have to customize. But you could just use the _materials.ini and _styles.ini and leave the others set to your ini's so you dont lose your machine settings. or if you are starting from scratch, use mine and adjust as needed.
I also post-process the gcode through clean_gcode.py which is supplied by jcrotcholl https://github.com/jcrocholl/kossel/blo ... n_gcode.py
Re: Plexus's Kisslicer settings
Postby danman78 » 2015-Apr-Sat-18-Apr
Is it possible in any slicer to configure different layer heights within a single print. For instance I have a long print with tall walls, but at the top of the print there is more detail and would take forever to print in more detail. Or maybe some kind of algorithm that would detect layers with little detail and layers with more complex detail. Then automatically print simple layers with .3mm height and complex layers with .1-.06 heights. Obviously the detailed layers would require more layers... I think you get the point.....???
danman78
Postby RetireeJay » 2015-Apr-Sat-20-Apr
Slic3r can do this.
First of all, you can tell it to make the infill thicker, so that the outer layers can be thin while the infill goes faster with thicker layers.
Second, you can actually slice your model up into different tiers along the Z axis and specify different layer thickness within each tier. You access this feature under the "Settings" icon (gear), then use the "Layer" tab.
Postby danman78 » 2015-Apr-Sat-23-Apr
what about in repiter host using slic3r?
danman78
Postby RetireeJay » 2015-Apr-Sun-05-Apr
Postby danman78 » 2015-Apr-Mon-23-Apr
danman78
Return to Software usage talk
