[Solved] Be careful of Repetier 0.90C
Postby RetireeJay » 2013-Jul-Tue-14-Jul
I've been delighted using Repetier 0.90B, because of the wonderful new tools like EEPROM configuration and calculators for calibration.
But today I downloaded Repetier 0.90C, and it is broken on my system. I had to revert to 0.90B.
I'm running Windows 7, and a Printrboard Rev D board with the original software. When I connected using Repetier 0.90C, the "connect" button turned green, but that's about the only thing that happened. Repetier said that 6 or 7 commands were waiting. It failed to download any info from the board, so it didn't have the EEPROM configuration available; it didn't even know if it was a Marlin board or whatever. (I never even tried to home an axis or anything like that).
Reverted to Repetier 0.90B and found joy again. :D
Re: Be careful of Repetier 0.90C
Postby davec » 2013-Jul-Tue-14-Jul
RJ, on Repetier 0.90C, under the Config, Printer Settings - 'Reset on Connect' change to disabled. That seems to have worked for me. I've been busy and haven't printed anything yet with the new version, but can home all axis and extruded.
Dave
  • 2
davec
Postby phil_roberts » 2013-Jul-Tue-22-Jul
Thanks! I was having trouble connecting. This fixed it.
phil_roberts
Postby RetireeJay » 2013-Jul-Wed-08-Jul
OK, the solution is available. Here's how to do it.
1) click on the "Printer Settings" icon in the upper right. (The Config: Printer Settings will be disabled if you have the problem)
2) In the window that comes up, look at the line for "Reset on Connect" - it probably has some settings about "DTR." That's "Data Terminal Ready" - ancient technology for establishing "ready or not ready" conditions for the RS-232 lines connecting "teletypes" to "modems" that worked over copper wire "phone lines." I have no idea why they would be using DTR on a USB serial connection. If the supposed DTR signal is not in the right state, then communications won't happen. But our communication is using USB, so just set it to "Disabled"
Re: [Solved] Be careful of Repetier 0.90C
Postby ei8htohms » 2013-Jul-Fri-17-Jul
Ah, good to know. Had trouble getting commands to go through after the update and didn't know why. Sending commands from the LCD encoder seemed to snap the bot (host) out of it but had no idea why.
Printrbot GO v.1 - steampunk
Igus DryLin nuts
PB LCD/encoder
GT2 belts
Twin 30mm fans
http://ei8htohms.tinyparts.net
ei8htohms
Postby JasperJ » 2013-Jul-Mon-00-Jul
Arduino repurposed the DTR line on their usb to rs232 chips a couple years back to implement a PC-triggered reset, for the purposes of uploading software.
JasperJ
Postby vw1610 » 2013-Sep-Sat-14-Sep
davec wrote:RJ, on Repetier 0.90C, under the Config, Printer Settings - 'Reset on Connect' change to disabled. That seems to have worked for me. I've been busy and haven't printed anything yet with the new version, but can home all axis and extruded.
Dave
This worked for me :)
vw1610
Postby JonS » 2013-Sep-Sat-15-Sep
Clicking on the "OK" button in the manual control button also resolves the problem.
Printrbot Metal Plus with:
- Dual Gear Head extruders
- Heated bed
- PEI print bed film
JonS
Return to Software usage talk
