Repetier Host / Slic3r
Postby jknightandkarr » 2018-Dec-Tue-23-Dec
Finally getting back into my 1405 printer, been down quite a while due to the horrible amount of y-axis sag and inability to level the print bed. Fixed the sag using 18 ga stiff wire to sew the thing togeather, fixed the sag, and then made a frame support using an old clipboard and raised the bed up with springs and longer screws. Now since I lost ALL my settings quite a while ago, can anyone give me their settings for Repetier-Host and Slic3r? I got it printing good, I used https://www.thingiverse.com/thing:2806295 to try and see the results. I terminated the print little early due to forgetting about the support material option being turned on, so kinda screwed it up alittle. I want to get it fine tuned now as much as possible, as fast as possible. I know the software has changed alittle over the years, and the original documentation has gotten me back to printing, but deffinatly needs work, so if anyone can show me their settings or recommend some settings, that'd really be helpfull.
I have my current setup as this:
0.4mm nozzle
1.75mm pla filament
heated bed-Temp at 70 deg C
ubis metal hotend (one that came with fan, not the ubis 13)-Temp at 205 deg C
Need to replace Kapton tape but for the moment it's still useable. Might try piece of glass to replace it, though will have to figure out accessing screws to relevel the bed.
I added a photo of the print i did to show what its doing.
Thanks!
Joe
~Starfleet Captain Joe R.
jknightandkarr
Re: Repetier Host / Slic3r
Postby RetireeJay » 2018-Dec-Wed-08-Dec
It looks like your belts may be loose - the positioning in both X and Y seems a little erratic. If the belts are tight, then check the setscrews that hold the toothed pulleys onto the motor shafts - they should be centered on the flats and should be secure so the pulleys can't rotate on the shafts.
Also, I'd say to check your Extruder calibration. If you issue a manual command to the printer to extrude 100mm of filament, then 100mm of filament should move through the extruder. Use a marker to put a dot on the incoming filament and see how far it moves. Full instructions for doing this calibration should be easy to find; they've been posted both in this forum and in other locations on the web.
Finally, I like to use a digital caliper to measure the actual diameter of my filament. It's generally not exactly 1.750mm. Also, it's generally slightly oval, so you have to take a measurement of the largest "diameter" and the smallest "diameter" at a point on the filament, and average the two. It's best to do this with a short segment of filament that you cut off so it's easier to make accurate measurements.
Postby jknightandkarr » 2018-Dec-Wed-17-Dec
Belts and the pulleys are fine, measured 50mm on filament, clicked the 50 on repetier host and distance dropped from 50 to like 23 using fast mode and from 50 to like 2 mm on slow.
Joe
jknightandkarr
Postby RetireeJay » 2018-Dec-Wed-17-Dec
Try something simple like a 10mm X 10mm X 10mm cube; that may give you better information about what's going on. Once you can print a cube perfectly, then move on to the torture test to fine-tune stuff like speed, extruder temperature, fan speed, and even more fine-grained tests.
I'm attaching a Slic3r file from a couple of years ago, which I used with my Printrbot. I was using "3mm" filament on that printer.
Postby jknightandkarr » 2018-Dec-Wed-18-Dec
Lol already ahead of you. Was already printing a 20mm x 20mm x 20mm cube. I did check the filament and adjusted it, though will keep checking the diameter, also set temp to 195. Will do a temp test to see if that helps.
Joe
jknightandkarr
Could the z axis be pushing down on the prints at all? Whats the slicer setting to adjust it? Doing a temp test print now.
Joe
Edit: Temp test really not helpfull... lol changed layer height to 0.2 before I printed it, but going from my lighted 8x magnifier I'd say likw 200-210 deg C best temp range so maybe 205.
Edit2: did a torcher test. Not clean by any means but did finish it all without problems, except for like 2 spots, both in the same area.
jknightandkarr
Postby jknightandkarr » 2018-Dec-Wed-21-Dec
Well... this thread is done....... My freaking Printrbot controll board just blew! What the heck......
Joe
Edit: Maybe not... my benchtop power supply didnt kick power off when I hooked it up to the control board n if it was blown n kicks pc power supply, will kick my benchtop supply. It's designed to kick power output off in event of short, so here's hoping its the power supply!
jknightandkarr
Postby jknightandkarr » 2018-Dec-Thu-16-Dec
Hooked the control board back up and while it powers on, x, y & z axis steppers don't move at all, and the software got disconnected from the board, so RIP Printrboard Rev F4......
jknightandkarr
Return to Software usage talk
