Cura With Plus V2.1
Cura With Plus V2.1
Postby tebw10 » 2016-Nov-Tue-12-Nov
I was looking into switching over and using CURA instead of Repetier. Am I able to just select the V2.1 profile and just be able to print away or will I need to input some additional settings into CURA?
tebw10
Cura With Plus V2.1
Re: Cura With Plus V2.1
Postby YellowGTO » 2017-Feb-Thu-18-Feb
I select printrbot metal and then type in the size of the bot manually. If you don't have an auto level sensor you'll have to take that out of the start Gcode.
G21 ;metric values
G90 ;absolute positioning
M106 ;start with the fan on
G28 X0 Y0 ;home X/Y
G28 Z0 ;home Z
G29 ;initiate auto bed leveling sequence
G92 E0
M107 ;start with the fan off
Thats my start Gcode for Cura.
YellowGTO
Return to Software usage talk
