Printrbot Talk Forum • View topic - How to use @pause in Repetier [SOLVED]
Postby RetireeJay » 2016-Jun-Wed-11-Jun
Re: How to use @pause in Repetier [SOLVED]
Postby RetireeJay » 2016-Jun-Wed-14-Jun
Well, the answer is that the way Slic3r counts layers is different from the way Repetier counts layers.
Slic3r's G-code starts with (un-labeled) Layer 0, and the first layer above that is labeled Layer (1) etc. But Repetier starts by counting the first layer as Layer 1. So when I used Repetier's Visualization "Show Layer Range" to see the layer that I wanted to stop at, the count according to Repetier (9) was one higher than the count according to Slic3r. When I searched for the layer to stop in the G-code, I was searching for tags produced by Slic3r, not Repetier, so I was off by one.
You do need to use lowercase for the @pause command, but an "information parameter" following the @pause is optional, not required.
Return to Software usage talk
Users browsing this forum: Bing [Bot] and 2 guests
