Printrbot Talk Forum • View topic - Source code for Printrbot Rev F Printrboard
Postby ChinookTx » 2016-May-Mon-14-May
Where does one get the source code for the Printrbot Rev F Printrboard? I'd like to roll my own with my calibrated values but can't seem to find a definite link to the firmware.
Tanks!
PrintrBot Simple Metal
E3Dv6 Hotend @0.4mm
Upgraded to heated bed + XY extension from Matrix Precision
ChinookTx
Re: Source code for Printrbot Rev F Printrboard
Postby RetireeJay » 2016-May-Mon-15-May
I think this is one valid place:
I don't know what happened to the link that used to be on Printrbot.com; they had a table there where you could select which printer type you were using and get the source code pre-configured. But where did it go????
Anyway, I have to ask what you mean about using your own "calibrated values." The calibration values for steps/mm in X, Y, Z, and E are all stored in EEPROM. Also, the printable dimensions are there. And a ton of other things; issue an M503 command to your printer and examine the return data that you get. You only need to edit source code and re-compile if (A) something you want to change is not in the EEPROM, or (B) if you are going into some kind of production mode where you want to reproduce your own version of calibrated settings on more than one printer.
Postby ChinookTx » 2016-May-Mon-17-May
Thanks, looks legit enough! All the values appear to map to what I have right now... Thanks again!
E3Dv6 Hotend @0.4mm
ChinookTx
Return to Software usage talk
