Printrbot Talk Forum • View topic - Printer profile for Simple Metal in Octoprint?
Postby ChinookTx » 2016-Apr-Sat-07-Apr
Hi all!
Is there a printer profile somewhere that I can use for Octoprint with the Simple Metal? I'm having issues mapping some of the values from Cura to Octoprint.
Thanks!
PrintrBot Simple Metal
E3Dv6 Hotend @0.4mm
Upgraded to heated bed + XY extension from Matrix Precision
ChinookTx
Re: Printer profile for Simple Metal in Octoprint?
Postby cacb » 2016-May-Tue-08-May
cacb
Postby ChinookTx » 2016-May-Tue-10-May
E3Dv6 Hotend @0.4mm
ChinookTx
Postby cacb » 2016-May-Tue-15-May
cacb
Postby ChinookTx » 2016-May-Tue-16-May
I'm really surprised how fast the Pi 3 slices with OctoPrint. I'll play with Slic3r over the weekend and experiment! Thanks for the reply.
E3Dv6 Hotend @0.4mm
ChinookTx
Postby Corey Warren » 2016-May-Sat-23-May
I have setup several profiles for slicing directly through Octoprint, the speed is fine. Basically, you just set all the settings you want in Cura and save the profile. The problem I had was getting that file over the Raspberry Pi. I think I plugged a monitor, mouse and keyboard into the pi and brought up the GUI to get to my email or Onedrive files in order to get the profile file saved to the pi. I then imported it into Octoprint.
I hardly use it, however. I very often need to rotate or move the object to a different position on the print bed. You can't do that when importing a .stl file into Octoprint. It's going to place the object right in the center of the print bed and you can't move, scale or rotate the object at all. And, I prefer Slic3r anyway so I do my slicing elsewhere and import the gcode, also.
Corey Warren
Postby sgibbers17 » 2016-May-Sun-11-May
The main problem I have with octopi doing the slicing is everytime I need to make a setting change you have to use a pc and have cura save a new profile. If could change the print setting on the octopi I would use it again. Right now I find it much easier to save the gcode to the octopi.
Sent from my SM-T900 using Tapatalk
sgibbers17
Return to Software usage talk
