Printrbot Talk Forum • View topic - How are you smart guys editing .stl files?
Postby Corey Warren » 2016-Feb-Tue-20-Feb
I see people all over Thingiverse making design changes to other's .stl files. I've never been able to do this. I use Autodesk Inventor to do make my creations. I did install some addin a while back to Inventor to assist with the import of .stl files, but, it was very difficult to deal with. Everytime I end up starting over from scratch and recreating what others have already created in order to add or remove.
How do you guys edit .stl files? What software do you use for that?
Corey Warren
Re: How are you smart guys editing .stl files?
Postby sgibbers17 » 2016-Feb-Tue-21-Feb
Sketchup with these extentions.
https://extensions.sketchup.com/en/content/cleanup³
https://extensions.sketchup.com/en/cont ... -inspector²
cleanup³ will cleanup all the extra lines in the stl and solid inspector² will make sure the stl has now holes and will "hold water"
sgibbers17
Postby frankv » 2016-Feb-Wed-04-Feb
I don't think that's quite what he was asking. I think he's after importing an STL file to a CAD app so that it can be modified to create a new object.
I've done this once or twice, without having a good way to do it.
I import the STL into FreeCAD and use that to convert the mesh to a shape to a solid. Then export it as a STEP file and load that into OnShape.com. However, typically I end up "tracing" the STL shapes to make new sketches and extruding a new object. I'm also dabbling with Meshmixer and Meshlab. There's also some CAD conversion utilities, but they don't seem to be very successful either (limited set of source & destination formats, and the few that do have IGES or STEP output often refuse to work on most STL files.
I look forward to replies by smarter guys than me.
Postby WayTooManyHobbies » 2016-Feb-Wed-06-Feb
I don't know about qualifying for smart, but you can open STLs in OpenSCAD and edit them as solid objects directly. Fair warning, there is a learning curve involved. http://www.openscad.org
WayTooManyHobbies
Postby sgibbers17 » 2016-Feb-Wed-08-Feb
sgibbers17
Postby cacb » 2016-Feb-Wed-12-Feb
cacb
Postby Mooselake » 2016-Feb-Wed-15-Feb
Postby cacb » 2016-Feb-Wed-16-Feb
cacb
Return to Software usage talk
