Repetier 1.6.1 - output power display??
Postby RetireeJay » 2016-Feb-Tue-18-Feb
Through several versions of Repetier, I've been able to see the graph of the output power to my hot end and heated bed. But the latest version shows no power indication for the hot end (the graph is there, but blank or zero). I went back to 1.6.0, and it did show the power successfully - although both versions seem to max out at 50% instead of 100%.
But this got me curious - what is the G-code command that Repetier has been using to get a readout of the actual power being delivered? I can't find it in any list of G-code commands.
Not a disabling problem by any means, but curious nonetheless. And I can't seem to get registered to participate in the Repetier forum; it tells me it's sending me an e-mail, but nothing ever arrives. (Yes, I've checked the spam folder.)
Return to Software usage talk
