Printrbot Talk Forum • View topic - AngelScript CSG
AngelScript CSG
AngelScript CSG
Postby cacb » 2016-Jan-Wed-17-Jan
Sometimes, I write software and have recently been playing with what could be described as a preprocessor to OpenSCAD, I call it AngelScript CSG, see http://arnholm.org/angelscript-csg-part-2/
OpenSCAD is really great but sometimes I find the language a bit limiting, and I really wanted something that runs and allows me to change variables and do more expressive stuff. Some time ago, I found AngelScript http://www.angelcode.com/angelscript/ and I figured I could add CSG (Constructive Solid geometry) functionality to that general language.
Right now, you write some code in AngelScript CSG and "compile" it on the command line into an OpenSCAD .csg file and use OpenSCAD to create an STL. This is how it is now, it could change as I am experimenting. Today I designed an electronics box for a friend, using AngelScript CSG, and printed it with my Simple Metal:
Seems to work. I will probably do some more in this area.
cacb
AngelScript CSG
Re: AngelScript CSG
Postby Mooselake » 2016-Jan-Wed-19-Jan
A couple years back there was a sort of similar openSCAD preprocessor, but I can't remember it's name or find it with google. Among other things it was (going to be) good for rounded and chamfered edges. Guess it died out, but does anybody remember it or what it was called?
Re: AngelScript CSG
Postby cacb » 2016-Jan-Thu-01-Jan
cacb
Re: AngelScript CSG
Postby cacb » 2016-Jan-Mon-14-Jan
I have been doing some more work on this. It is now much easier to use with the new GUI editor/IDE that allows script writing, simple debugging and more:
http://arnholm.org/angelscript-csg-ide/
cacb
Re: AngelScript CSG
Postby Mooselake » 2016-Jan-Mon-16-Jan
I ignored the Windows 10 "We're all gonna die if you install this" :) error (click on more info, then run anyway), and seem to have survived. W10 Pro 64b insider preview 11102.rs1.
You posted this at the perfect time. I need to design a diamond shaped part to hold a couple screws with nut traps for my never-ending adjustable laser cutter table, followed by a stand for MT2 lathe accessories (think solid box with tapered holes in the top). We'll see how fast old moose pick up new programming things.
Re: AngelScript CSG
Postby cacb » 2016-Jan-Mon-16-Jan
cacb
Re: AngelScript CSG
Postby Mooselake » 2016-Jan-Mon-17-Jan
Re: AngelScript CSG
Re: AngelScript CSG
Postby Mooselake » 2016-Jan-Mon-18-Jan
Looks good (well, needs a few more top layers at 120mm/s), need to make it a little bigger because the corner screws don't align with the steel mesh at the same place, but that's my problem and not AngelScript's.
Re: AngelScript CSG
Postby cacb » 2016-Jan-Mon-18-Jan
cacb
Re: AngelScript CSG
cacb
Re: AngelScript CSG
Thanks!
I won't be able to get back to it until Wednesday afternoon or Thursday, have to work from late tomorrow morning until 6am Wednesday. We have a bridge that's undergoing maintenance every night this week and need an extra ambulance crew to cover the service area south of it - it's the only way across. I didn't look at my caller ID quick enough...
Not very good at explaining that "almost retired" doesn't mean "unlimited free time, call for everything".
Re: AngelScript CSG
Postby cacb » 2016-Jan-Tue-09-Jan
cacb
Re: AngelScript CSG
Postby Mooselake » 2016-Feb-Mon-14-Feb
Re: AngelScript CSG
Postby cacb » 2016-Feb-Mon-15-Feb
cacb
Re: AngelScript CSG
cacb
Re: AngelScript CSG
Postby Mooselake » 2016-Feb-Mon-17-Feb
Thanks! inches(n) does look cooler than n*25.4, should have caught that on.
Cone is in your list in part-2 with only one argument, didn't know you took variable length argument lists. If that works the same way as cylinder then it's exactly what I need.
The LP gas truck got stuck in the driveway, helped dig them out but I need to go out and plow off the chewed up mess. Worst part is my tank is 70% and with the wood heat it won't move much while the outdoor boiler is trying to burn up half the north woods. Not real efficient... I'll make the changes as soon as I make it back in.
Dang snow, just keeps coming, although this years 110" is a lot less than this time last year.
Re: AngelScript CSG
Postby cacb » 2016-Feb-Mon-17-Feb
cacb
Re: AngelScript CSG
Postby Mooselake » 2016-Feb-Sat-13-Feb
Re: AngelScript CSG
Postby cacb » 2016-Feb-Sat-14-Feb
cacb
Re: AngelScript CSG
Postby Mooselake » 2016-Feb-Sat-14-Feb
Reason: swap arguments to cone
Re: AngelScript CSG
Postby cacb » 2016-Feb-Sat-15-Feb
cacb
Re: AngelScript CSG
Postby Mooselake » 2016-Feb-Sat-17-Feb
Sound of hoof smacking forehead. I knew that.
I made the taper the proper length and let the hole extend above the box. The way I had it before the taper was too short so the angle would have been off. Not that it was critical, but might as well do it right.
I had an extruder jam about an hour and a half into the two and a half hour print (my first with the AMU hot end). Disassembled the extruder, burned out the nozzle and heated the barrel enough to remove the jammed filament. For good luck I took a string and some polishing compound and worked on the inside for a while. Edited the gcode and restarted the print. There's a bump where it jammed, but it should file out. Fingers crossed...
Thanks again!
Return to Software usage talk
