Printrbot Talk Forum • View topic - End command line
End command line
End command line
Postby calex_fr » 2015-Nov-Sun-10-Nov
Hi every body.
I have a little problem, at the end of my prints the head go home and some time touch my print and scratch it!
I would to know if it will be possible to program automatically Z+10 at the end to go up the head ?
Regards
Alex
alex from France
Printrbot Simple Metal with heat bed, extruder V2 and Ubis 13 upgrades
and second PB Simple Metal extruder V2.
calex_fr
End command line
Re: End command line
Postby RetireeJay » 2015-Nov-Sun-10-Nov
Bien sur (Definitely)
Here is my end code:
M104 S0 ; turn off temperature
G91 ; set relative positioning
G1 Z10 ;Raise the head 10mm above the object
G28 X0 ; home X axis
M84 ; disable motors
By the way, I hope you and your family and friends are doing OK. I pray for France, and also for the defeat of terrorism.
Postby calex_fr » 2015-Nov-Sun-11-Nov
alex from France
calex_fr
Return to Software usage talk
