Printrbot Metal Plus Dual / S3D - Offsets?
Postby samuraiken » 2015-Nov-Sat-16-Nov
Hey guys!
I am running a Plus / Dual with Simplify3D and no matter what I do, the dual extruders seem offset in X. Yes, they do seem offset by the 45MM they are claimed to be - but no setting I can find in S3D or the Firmware seems to regulate this. S3D does have a tool offset under their "G-Code dialog, but the settings themselves never seem to be used... at least, no setting there seems to change anything.
Anyone have this working and can share their settings?
Ken
samuraiken
Re: Printrbot Metal Plus Dual / S3D - Offsets?
Postby bbrown64 » 2015-Nov-Sun-10-Nov
I found this at Printrbot. I do not know if it will help. http://help.printrbot.com/Guide/Getting+Started+Guide+-+Dual+Extrusion/209
Bill Brown
Tulsa, OK
bbrown64
Postby JonS » 2015-Nov-Thu-00-Nov
I don't use S3D's tool offsets, as I don't think it was available in the version I started with, and I cut and pasted from my Repetier settings.
In my Starting Script I have:
M218 T1 X47.15 Y-0.35 ; extruder 2 offset
Which are my calibrated offsets. Yours will vary slightly.
Printrbot Metal Plus with:
- Dual Gear Head extruders
- Heated bed
- PEI print bed film
JonS
Postby SpannerHands » 2015-Nov-Fri-02-Nov
samuraiken wrote:Hey guys!
Ken
Hi Ken
The offset settings in S3D does nothing, as it does not generate any code in the gcode file sent to the printer...
What I did is add some code to the "Starting Script" under the "Scripts" settings tab in process settings :
M218 T0 X0 Y0; Tool 0 Offset
M218 T1 X-47.25 Y-0.42; Tool 1 Offset < but use your adjustments...
G28 X0 Y0 ; home X and Y axes
G29 ; probe Z
Spannerhands...
Everything for your 3D & Filament Needs.
3D Printing Filaments PLA, ABS, Wood, Transparent, Flexable and Technical Materials.
www.spannerhands.co.uk
SpannerHands
Return to Software usage talk
