Printrbot Talk Forum • View topic - Repetier -Printer Shape settings for Metal Plus
Postby ThriDee » 2015-Sep-Fri-01-Sep
This is mildly bewildering as i post this.I had a Printrbot Plus (Kickstarter edition) which I sold since I was in the middle of college.I finished college :mrgreen: :mrgreen: :mrgreen: and got myself a Printrbot Metal Plus.(Printrbot fan for life!) :P :P :P
I turned on my well trusted Repetier Host and connected the assembled metal plus and tweaked some settings like Z-compensation,Print speeds,.Result: It prints awesome! :mrgreen: :mrgreen: :mrgreen:
But it's still configured as per the Printrbot plus sizing.
Can any of you Metal Plus owners provide a screenshot of the Printer Shape tab under Printer Settings.
Also my when I hit the combined XYZ home on the Manual Control of Repetier the X and Y home correctly but for homing Z the extruder moves to the center of the bed.
Any fix for this in Repetier ?
ThriDee
Re: Repetier -Printer Shape settings for Metal Plus
Postby RetireeJay » 2015-Sep-Fri-09-Sep
From what I've seen in the forum, if you have the Autoleveling Probe, then you do NOT do the combined XYZ Home.
You could individually hit the X and Y "home" buttons, or you could use the command line to enter
G28 X0 Y0
Then for Z (assuming you do want to use the "Autoleveling", you use
G29
Then, after issuing the G29 and watching it do the 3-point probing, I think you have to issue another
G28 X0 Y0 to get the X and Y coordinates correctly zeroed.
Postby cacb » 2015-Sep-Fri-15-Sep
cacb
Postby thawkins » 2015-Sep-Fri-19-Sep
Postby RetireeJay » 2015-Sep-Fri-21-Sep
@thawkins, you are deep into the Marlin code, so you know what you're talking about.
But I do think I've seen in other threads where people did G28 - G29 and ended up with the printer's XY "home" offset. They had to do a G28 X0 Y0 after the G29. So you are saying that any form of a G28, even if it doesn't include Z, still throws away the bed leveling? I'm not doubting your in-depth expertise, but I'm trying to reconcile what I've seen in other people's experience.
Postby cacb » 2015-Sep-Fri-21-Sep
cacb
Postby thawkins » 2015-Sep-Sat-00-Sep
Postby ThriDee » 2015-Sep-Sat-01-Sep
Thank you RetireeJay and thawkins.I can't believe RetireeJay was the first to answer my first question on Printrbot Plus and the is the first to answer here as well !
I added this as the start G-code
G28 X0 Y0 Z0
G92 E0
G29
And This as the End code
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
Still need a screenshot of the Printerbot Metal Plus Printer Shape settings for Repetier (v 1.6) so i can make the best of the large print bed.
Anyone ?
Also what are the major upgrades (vis-a-vis Printrbot models) that went into Repetier in the last one year?
Should I upgrade to the last free version or should I not ?
ThriDee
Return to Software usage talk
