Printrbot Talk Forum • View topic - Cura 15.X With PBs
Cura 15.X With PBs
Cura 15.X With PBs
Postby MileHigh3DII » 2015-Jul-Sat-20-Jul
Anyone using them yet? I've been a fan of the older versions of Cura, but this one has be a bit fuddled. I can understand why Brook would want low time users to use Cura- and this new version seems even easier to start up with.
-I don't see how to get a printer set up outside of the UM listed printers. Web postings talk about JSON files, but I'm not finding any my system or how to edit them.
That's my main issue right now. Being able to tweak extrusion, speed and temp as in Repetier is a feature I'd like. Dual for my PB+Dual I guess will come later?
I'd like to get a JSON file set up for the PB with out setting out on an Iliad type adventure.
MileHigh3DII
Cura 15.X With PBs
Re: Cura 15.X With PBs
Postby Mooselake » 2015-Jul-Mon-09-Jul
I did a quick poking around in the Cura knowledge base and came up blank, but look in the advanced settings for speeds, bed size, etc.
Repetier never let you tweak extrusion, speed, or temp since it's not a slicer. It will call slicers, and call up their configuration settings, automatically but (well, other than controlling it's gcode display, which is in a different setup menu item) never had anything to do with them directly.
Is there a printer config file for the latest version of Cura on help.printrbot.com ?
Postby teicher » 2015-Jul-Mon-11-Jul
There was a post on the ultimaker forum where a user modified the json file for a deltaprinter and I think they included the filepath. You might try copying that example.
I decided it wasn't worth the hassle to use the new version at this time. There are already bugs filed for slower slicing speeds, etc. I figured it was worth waiting a little longer.
teicher
Postby thawkins » 2015-Jul-Mon-12-Jul
Postby teicher » 2015-Jul-Mon-12-Jul
teicher
Postby MileHigh3DII » 2015-Jul-Thu-16-Jul
MileHigh3DII
Postby Willy » 2015-Jul-Sun-19-Jul
Not wanting to make a new thread on Cura and Printrbot, I have a different question.
When I run Cura it plants the object in the middle. Yet when I print, for some reason the object is moved all the way to the right of the bed.
Another problem I am having is, if I move the item to another area of the bed, the printer warms up, but cura sits there at 25 and wont reflect that the temp has changed. It will only print if I dont move the item to be printed.
Willy
Postby thawkins » 2015-Jul-Sun-21-Jul
Postby Willy » 2015-Jul-Mon-05-Jul
Machine Settings
Machine center 0,0 box is NOT checked. Problem still exists. Print area set at 154x154x154
Willy
Return to Software usage talk
