visible 3 steps in part of larger prints
Postby xs32 » 2015-Jun-Mon-09-Jun
Hello community
I need help with a strange behavior with my new Printrbot maker kit which works great except for this (potentially software based) bug
Two larger objects I have resized or rotated and printed using Cura 15.04 show 3 visible "steps" or X offset. When i print the object twice, the steps happen again in the same place (just to make sure it wasn't a random accident)
I'm thinking this is a Cura bug more than anything else but I didn't find any sign of it in the forums or the Cura github so I was curious as to whether there is experience with the people on this forum.
Thanks!
Stephane
xs32
Re: visible 3 steps in part of larger prints
trying to post pictures and links to source to illustrate. Any idea how to link to pictures or files as a new user?
xs32
Postby PxT » 2015-Jun-Mon-12-Jun
How to post photos: viewtopic.php?f=7&t=6771
Postby xs32 » 2015-Jun-Mon-13-Jun
See pictures and files attached.
The rodin statue has the 3 steps offset between knees and butt, The STL file is attached as well
The gremlin status has the 3 steps offset on the ears. The STL file is 50MB, if you want to download it, just search for Gimli in Tingiverse
xs32
Postby RetireeJay » 2015-Jun-Mon-13-Jun
It looks like these objects may have exceeded the build boundaries of your printer. The maximum size limits in X and Y extend all the way up to the top of the Z travel. If the printer tries to move beyond the maximum (or negatively beyond zero) then it won't actually go there, but it loses the steps that would have taken it there.
Postby xs32 » 2015-Jun-Mon-14-Jun
Thanks for looking into this Jay but I doubt it's even close to the upper limit from the printrbot maker's kit. In the case of the Rodin statue, the problem manifest itself almost exactly in the middle of the statue at apprx. 1.5 inches high. Aside from this defect, the rest of the statue (about 4 inches high) printed incredibly well and smooth.
Is there a way in Cura (or using some export tool) to see what the expected 3D outcome would have been according to the data Cura is going to send to the printer (if that makes sense)
xs32
I should add I am using the Printrbot simple makers kit template from Cura that shows a printable area of 100mm in every direction (not sure if that's a known incorrect setting)
xs32
Postby RetireeJay » 2015-Jun-Mon-17-Jun
xs32 wrote:In the case of the Rodin statue, the problem manifest itself almost exactly in the middle of the statue at apprx. 1.5 inches high. Aside from this defect, the rest of the statue (about 4 inches high) printed incredibly well and smooth.
Perhaps I wasn't clear. It wouldn't matter if your model was only 1/4 inch high. Height has nothing whatsoever to do with the problem I was describing. It's how far in X and Y that your printer has to travel to make the model. It's clear that your models grow larger in X and Y as you go up in Z. And in the case of the Rodin statue, it looks like the knees are where the print reaches its maximum extent in the X-Y plane. What are the maximum dimensions of your model in X and Y (the slicing program should tell you what the maximum X and Y are)? In other words, if you had the sun directly overhead, would the shadow of the (good) print go outside the printable area of the bed?
xs32 wrote:I should add I am using the Printrbot simple makers kit template from Cura that shows a printable area of 100mm in every direction (not sure if that's a known incorrect setting)
You need to have your maximum dimensions set to agree with each other everywhere. That means in Cura and also in the EEPROM (M211) settings of the printer. If you are using Repetier, set the maximum bed dimensions there, too.
Postby xs32 » 2015-Jun-Mon-17-Jun
Got it. Thank you for your patience and wisdom. Cura says the object size is X:72mm Y:48.84mm Z:97mm
I can't answer your question about whether the shadow would go outside of the printable area (it's not obvious to me what it is looking at the bed) but the problem areas are indeed towards the limit of where the printer prints.
M211 returned nothing but M501 returned this:
> M501
< echo:Stored settings retrieved
< echo:Steps per unit:
< echo: M92 X80.00 Y80.00 Z2020.00 E96.00
< echo: M203 X125.00 Y125.00 Z5.00 E14.00
< echo:Home offset (mm):
< echo:PID settings:
< echo:Min position (mm):
< echo:Max position (mm):
< echo: M211 X100.00 Y100.00 Z115.00
< echo:Bed probe offset (mm):
< echo: M212 X25.00 Y0.00 Z-1.10
The M211 settings seem to align with the ones from Cura (100mm in every direction).
Does this help confirm we're dealing with an XY plane dimension issue? If so, should i calibrate the bed or modify a printer setting in Cura?
xs32
Postby RetireeJay » 2015-Jun-Mon-18-Jun
Well, OK, you've got me convinced that my hypothesis is all wet. Your object SHOULD print without running afoul of the boundaries. I don't have another theory to suggest.
Unless... the print is not centered. There must be a setting in Cura somewhere that says where to place the center of the print, and that should be at 50, 50 from the dimensions you gave. Also, some people have encountered problems with the print starting off-center due to some mysterious mumbo-jumbo with the bed probing sequence. I don't have that stuff, so I can't easily tell you how to troubleshoot that. But basically, the print (all of it, not just the base) should be centered on the bed. If you dropped a vertical line from the statue's knees as printed, would that line be well within the bounds of the printable area?
Postby Mach-Chris » 2015-Jun-Mon-20-Jun
RetireeJay wrote:Well, OK, you've got me convinced that my hypothesis is all wet. Your object SHOULD print without running afoul of the boundaries. I don't have another theory to suggest.
WRT Mumbo jumbo, as far as I have figured, in my experience anyways, is that the M212 X25.00 is what tends to shift the prints from the desired centre of the bed. My best guess is that the autolevel routine is supposed to be using this offset value to better map the bed relative to the nozzle, since the probe IS roughly 25mm X+ from the nozzle. However, it would seem that what ends up happening (according to a post I found, reddit I think ) is that the machine's position ends up being shifted at the conclusion of the probing routine. SO, in light of that, there are a few options you have here. One would be to play with the M211 X value (ex: M211 X10.) and print some test prints, and wash, rinse,repeat until you find values that result in your print being in the same position as Cura slices them in. The other option, is to put an M92 in your "starting gcode" sequence AFTER the G29 that will actually reset where the printer thinks it is. To do this you would have to read off the echo positions of the probing routine, and do some math to figure out where is SHOULD think it is. If I recall correctly from my playing around in the configuration.H file of marlin for PBSM. the default probe Inset from max X travel is 10mm which would mean that If you have 100mm x travel, the probing routine would probe its last point at X90. You should still double check these numbers yourself though.
Good luck!
Visit Matrix Online!
Mach-Chris
Postby xs32 » 2015-Jun-Mon-20-Jun
You figured it out both of you. Although you must be half blind to miss it, I didn't realize I was always printing off the bed center by 15mm so the M212 X10 (didn't forget to save!) was the fix. Seeing that now there are a numbers of online threads about printrbot off center problems and a number of G29 suggestions (none of which worked for me because all printers are different), it appears to me this is a known issue affecting a number of printrbot (potentially other) people. I wonder why the Printrbot firmware comes out of the box with this offset of 25 (M212 X25.00 Y0.00 Z-0.20) rather than 15 --- maybe good feedback for the product team. Anyway thanks to both of your for your time and help and patience. Looks like I'm good to print larger models in good conditions.
xs32
Postby RetireeJay » 2015-Jun-Mon-21-Jun
I'm not sure, but I think another solution is to do a G28 X0 Y0 command AFTER the G29 command. This resets the X and Y zero positions without affecting the Z correction. But I may be off-base on this; let us know if that works.
Return to Software usage talk
