Printrbot Talk Forum • View topic - Auto leveling not working
Postby Chris Knowlton » 2015-May-Sat-11-May
Hi all,
I have a Printrbot simple metal and have been printing successfully for months. But lately it appears that the auto leveling system is not working properly. I tested the Z stop using the M119 command at all three corners and it correctly registers as “0” or “triggered” when the extruder is raised and lowered by hand. My bed is fairly level and the Z motor is moving a little while each layer is printing but it is not compensating (or not compensating enough) when printing. The first layer width varies greatly from one side of the bed to the other.
Any suggestions?
Thanks,
Chris
Chris Knowlton
Re: Auto leveling not working
Postby veng » 2015-May-Sat-15-May
Execute a G29 from Pronterface or some similar program but not the Pronterface like UI in Cura which doesn't seem to have an output window that I can find. Hold your hand on the power switch in case of a problem.
You should get three (or maybe four if you changed config.h) co-ordinates in the output window. The X and Y should correspond to where the probe was when testing while the z value is what is used to calculate the plane. There should probably be some difference in the z values or either your bed is extremely level or something isn't working.
It only compensates for tilt in the plane. If the bed is bent, auto-leveling won't cure that.
In an experimental set-up where I'm trying a different sensor than the Printrbot with longer sensing measuring through glass, I'm getting z values of-0.37, 1.48, 1.06, 0.02 on a totally unleveled bed. Obviously I should level it up better than that.
veng
Postby frankv » 2015-May-Sun-00-May
Something has changed, and it ain't software or electronics. Check for play in the X, Y, and especially Z axes.
If the bed was extremely level, the Z axis wouldn't be turning whilst printing... only intermittently when starting a new layer. Actually, IMHO it is worth levelling your bed to be that level... it takes one, or several, variables out of the problem-solving loop. When you use auto-levelling, an error in one axis can cause a symptom in another axis.
frankv
First blob a success!
Postby cacb » 2015-May-Sun-03-May
cacb
