Cura G29 problem
Cura G29 problem
Postby printer999 » 2015-Apr-Fri-22-Apr
Hi I have been using a Printrbot plus 2.1 with dual extruders and a bed leveling probe for a while now, I recently updated cura, and the probe stopped working the same way. The G29 command does all the points except the 3rd and 4th point correctly. The leveling seems to work fine untill the third point, where instead of moving down torwards the bed, the Z goes up and the leveling probe seems to activate at that point as well. And it does the same when it goes to the 4th point. Then it goes back to normal for the 5-9 point. I dont know whats going on. There are also These plugins active, In the new verison of Cura, and i dont know if they are active or not, or if they do anything. I think it may be because I updated cura or something My start Gcode is
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M104 S{print_temperature} ;Uncomment to add your own temperature line
;M109 T1 S{print_temperature2} ;Uncomment to add your own temperature line
;M109 T0 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M107 ;start with the fan off
G28 ;move to endstops
G29
G91 ;relative positioning
G1 X-20 Z-0.2 F{travel_speed} ;move Z up a bit and retract filament even more
T1 ;Switch to the 2nd extruder
G92 E0 ;zero the extruded length
G1 F200 E15 ;extrude 15mm of feed stock
G92 E0 ;zero the extruded length again
G1 F200 E-{retraction_dual_amount}
T0 ;Switch to the first extruder
G1 F{travel_speed}
;Put printing message on LCD screen
M117 Printing...
Thanks in advance for the help
printer999
Cura G29 problem
Re: Cura G29 problem
Postby frankv » 2015-Apr-Sat-04-Apr
What you describe is typical of a broken Z probe wire... it is intermittent because the wire is broken, but still touching when the head is in one position, but not quite touching for the others.
frankv
First blob a success!
Postby printer999 » 2015-Apr-Sun-03-Apr
Is it possible to solder it back up, or do i need to order a new one.
printer999
Postby frankv » 2015-Apr-Sun-03-Apr
Probes are quite cheap, only 4 or 5 dollars, so I wouldn't bother repairing it. Probably where one wire is intermittent, more than one is nearly broken. When my first one died, I could identify two different places where wires were broken. There's no harm done in trying to repair it though.
My own solution, though, was to level the bed manually and not use auto-leveling at all.
frankv
