Cura filling my hardrive during printing
Postby The Virus » 2015-Mar-Wed-19-Mar
When I'm printing using Cura my hardrive freespace is being filled as if Cura's logging every movement, I've used 35 Gb of space and cannot find where all this is being stored or why. Anyone have any insight?
Im running OSX 10.7.5, Cura 15.02.1 with Printrbot metal plus.
Any help would be awesome since my drive is now full and Im stuck.
The Virus
Re: Cura filling my hardrive during printing
Postby thawkins » 2015-Mar-Thu-21-Mar
The Virus wrote:When I'm printing using Cura my hardrive freespace is being filled as if Cura's logging every movement, I've used 35 Gb of space and cannot find where all this is being stored or why. Anyone have any insight?
Im running ISX 10.7.5, Cura 15.02.1 with Printrbot metal plus.
What operating system are you using
If linux based the output files will be in /tmp
Postby orangefurball » 2015-Mar-Fri-06-Mar
thawkins wrote:What operating system are you using
Cough cough
The Virus wrote:Im running OSX 10.7.5, Cura 15.02.1 with Printrbot metal plus.
Thingybot Delta Printer
http://www.thingybot3d.com
orangefurball
Laser scintillater
Postby thawkins » 2015-Mar-Fri-08-Mar
Cough cough
Oops missed that
Ok on osx the
Temp files are in either
/var/tmp
or
/private/tmp
If you want to see them in finder then open a command shell and type
sudo open /private/tmp
sudo open /var/tmp
A finder window should open with the folder contents in view and root rights so you can delete files.
Be carefull as you will have root permissions in that window, once you have inspected the contents and deleted any temps that are relevant then close the window. dont leave it open a second longer than it needs to be.
Postby PxT » 2015-Mar-Fri-16-Mar
thawkins wrote:If you want to see them in finder then open a command shell and type
sudo open /var/tmp
Absolutely no reason to use sudo for that, you can open either of those as a normal user. If you need to authenticate to delete a particular file then Finder will prompt for that.
You can also just hit Cmd-Shift-G from any open Finder window (or choose the Go -> Go To Folder… menu item) and then type the path to go directly to a chosen directory.
Postby The Virus » 2015-Mar-Fri-21-Mar
I located some files in those folders named:
in /private/temp
KSOutOfProcessFetcher.501.IW-ShwaXJwmHlkfc5wb2ZMHOaJY=
launch-cRRMfh
launch-hsz6ZS
launch-TGeFaN
launch-Xcr8KV
launchd-145.Q8Vdpv
launchd-373.fLuY7M
launchd-559.O8nqr2
all appear to contain nothing other than the first file in the list. That contains ksfetch a 514kb unix executable file.
/temp contains only
launchd which has 0kb
Im kinda stuck here (obviously). It's using around 1Gb ever 2 or 3 minutes of printing.
The Virus
Postby orangefurball » 2015-Mar-Fri-21-Mar
The Virus wrote:I located some files in those folders named:
in /private/temp
launch-cRRMfh
launch-hsz6ZS
launch-TGeFaN
launch-Xcr8KV
launchd-145.Q8Vdpv
launchd-373.fLuY7M
launchd-559.O8nqr2
/temp contains only
Are you on the latest Cura? My Macbook is fine when printing. Just uses the space for the GCode
orangefurball
Laser scintillater
I also tries a print in Repetier and the same results..........
The Virus
The Virus wrote:I also tries a print in Repetier and the same results..........
Are you using Curaengine in Repetier? or Slic3r?
orangefurball
Laser scintillater
Postby The Virus » 2015-Mar-Fri-23-Mar
I was using Slic3r in Repetier........
The Virus
Postby RetireeJay » 2015-Mar-Sat-07-Mar
Repetier does create a log file, but it shouldn't be anywhere near that large.
I'm on Windows, using the latest Repetier, and last night I finished a 6-hour print. The log file is 27,731 KB (under 28 Megabytes, or 0.028 Gig). That's in 360 minutes of printing.
So there is something very strange if you are seeing 1 Gig used up every 2 or 3 minutes. That's like a video rate, in the ballpark of 5 to 10 Meg per second. Is it somehow storing a copy of the progress picture every time it refreshes? Check the settings for your screen video adapter.
Postby PxT » 2015-Mar-Sat-14-Mar
Get Daisy Disk and find out exactly what is filling up your space: http://www.daisydiskapp.com
Postby thawkins » 2015-Mar-Sat-20-Mar
PxT wrote:Get Daisy Disk and find out exactly what is filling up your space: http://www.daisydiskapp.com
Or you could find the folder with the most data in it, the following instructions are for linux, but they will also work with mac osx which is unix based.
http://www.cyberciti.biz/faq/how-do-i-f ... ilesystem/
