Printrbot Talk Forum • View topic - Object Placement
Object Placement
Object Placement
Postby keljam7 » 2015-Jan-Sat-20-Jan
It is showing that it is center.
As you can see it is not.
I'm trying to fix it but no luck yet.
If you can help (Thanks alot), if you need any more info just let me know.
-kelly
keljam7
Object Placement
Re: Object Placement
Postby Mooselake » 2015-Jan-Sat-22-Jan
You need to specify the bed size in both Repetier-Host, and your slicing program. Looks like you missed the slicer.
If you're using slic3r it's under the Printer Settings tab; select General from the box on the left, then enter the correct numbers.
Postby captainserial » 2015-Jan-Sat-23-Jan
Bed size in the X direction is reduced to 210mm by the dual extruder carriage. That might be part of your problem. Z size is reduced as well (can't home X above a certain height).
captainserial
Postby dsegel » 2015-Jan-Sun-01-Jan
Check the head position my issuing a M114 command after the G29 process completes, then measure where it actually is with a ruler. If the numbers don't match up, let me know.
But that does look like it's just using the wrong extruder for positioning.
dsegel
Postby keljam7 » 2015-Jan-Tue-20-Jan
keljam7
