Printrbot Talk Forum • View topic - Problems with the G29 in Cura
Postby Roadrunner77 » 2015-Jan-Mon-17-Jan
Hello,
I have a problem with the G29 start G-code commend when using Cura.
The actual problem is the hight of the Z-axis after I started a print. Everything seems to work fine for the probing of the 3 points but when the printer actual starts to print the Z-axis it is too far above the print bed.
The results are partial drops on the brintbed which do not stick at all.
When using Cura without it everything works perfectly.
It is not such a big issue, as I can still print everything but I still wonder what might be wrong here.
The Z-probe seems to be fine (wiring, calibration, etc.). I assume it's a software issue in Cura as the normal print, without the G29 commend works well.
I would appreciate any help.
Kind regards
Roadrunner77
Re: Problems with the G29 in Cura
Postby musk » 2015-Jan-Mon-17-Jan
Have you calibrated the Z probe offset? It is mandatory for proper adhesion.
Printrbot Metal Plus (2x)
Printrbot Simple Metal (2x)
musk
Postby dsegel » 2015-Jan-Mon-18-Jan
Also make sure the probe is reasonably close to the bed when you start the G29 process. If it's more than about 30mm up then I get all kinds of weird responses, like it goes through the motions and acts like it's leveling, but it never goes down to the bed, and then it starts printing in mid-air.
dsegel
Postby thawkins » 2015-Jan-Mon-19-Jan
Postby Roadrunner77 » 2015-Jan-Wed-16-Jan
Hello everybody,
thanks for your quick response to my request. I still have the problem with the Z-axis offset.
@musk: Yes I calibrated the Z probe and checked my adjustment. I did this according to the user manual and an online guide I found on Youtube.
As I stated in my original post, without the G29 commend in the start G-Code everything works great, so I assume the calibration is correct?!
@dsegel: I tried several starting positions, but no changes.
My starting point is:
< X:0.00Y:152.40Z:0.90E:0.00 Count X: 0.00Y:152.40Z:0.90
@thawkins: My start gcode looks as follow:
;Sliced at: {day} {date} {time}
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G29
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
G1 F200 E3 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F{travel_speed}
M117 Printing...
Regards
Roadrunner77
