Printrbot Talk Forum • View topic - Can't get Marlin-Unified v2 to compile with Arduino 0022
Postby jeromedayton » 2014-Feb-Mon-16-Feb
Jerome
Retired Software Developer
Printrbot Simple operational since Xmas 2013
Printrbot Jr v 2 with alu extruder March 2014
jeromedayton
Re: Can't get Marlin-Unified v2 to compile with Arduino 0022
Postby PxT » 2014-Feb-Mon-19-Feb
Postby jeromedayton » 2014-Feb-Mon-20-Feb
Jerome
jeromedayton
Postby jeromedayton » 2014-Feb-Mon-21-Feb
One mystery solved. Apparently the Marlin.pde file IS the makefile that Arduino uses and any attempt to open the actual Makefile in that directory redirects you to this file.
Jerome
jeromedayton
Postby RetireeJay » 2014-Feb-Mon-21-Feb
Yeah, when I went searching for the software identification string that prints out when Repetier connects, I had to search file by file, using the Control-Alt-arrow key combination to move between files. When I finally found it, I discovered that there was no way to know WHAT file I was looking at! The list of tabs across the top had been used up and there was no tab highlighted. And there is no standardization within the files to say what the name of the file is on the first line.
But with enough sleuthing, I finally figured out it's in "Language.h" :)
Postby PxT » 2014-Feb-Tue-01-Feb
Postby jeromedayton » 2014-Feb-Tue-14-Feb
Woohoo success. I followed all of RetireeJay's directions for "How to install the 1.05 Arduino in Four Steps", restarted Arduino, selected Tools / Boards / "[usbtinyisp]Teensylu/Printrboard", selected Verify and it successfully compiled. I hadn't seen that choice for boards before and when I had compiled before, it always prompted me to set the board selection to "Teensys++ 2.0". So RJ you should add this to the firmware directions.
Now to see if I can get Eclipse to successfully load the project.
Jerome
jeromedayton
Postby RetireeJay » 2014-Feb-Tue-16-Feb
Postby jeromedayton » 2014-Feb-Tue-16-Feb
Jerome
jeromedayton
Postby PxT » 2014-Feb-Tue-19-Feb
What you're asking is non-trivial to accomplish but you can read here for a starting point: http://playground.arduino.cc/Code/Eclipse
Postby jeromedayton » 2014-Feb-Tue-20-Feb
PxT-
Thanks for the pointer. The plugin adds two things, one of which is needed. First it allows for an "Upload to Target Device" from the menu, which we can't use since we have to use Flip. But it DOES add the Arduino tool chain which we need to create an executable.
However it still needs the Makefile in the
https://github.com/Printrbot/Marlin/rel ... unified-v2
release to actually build with the command line Arduino toolset, which it doesn't do at present.
But I now have enough of Eclipse working that I can actually wander around the code and see stuff. I just can't compile. I'll have to make any changes I want in Eclipse and then go back to the Arduino IDE to actually get a flashable executable.
My motivation for this is my Printrbot Simple has been in-operable for almost 3 weeks now, with the dreaded: "Extruder switched off. MINTEMP triggered !" message and I can find no good cause for it. So I'm about to add some debug messages to that section of the code so I can see more precisely what is going on.
Jerome
jeromedayton
Postby PxT » 2014-Feb-Wed-14-Feb
It looks like the Makefile needs a couple of tweaks to work correctly with the at90usb1286 / Teensy chip variants that the Printrbot code is configured for.
Try this Makefile: https://gist.github.com/PxT/4b9c9809407 ... a/Makefile
Modify the ARDUINO_INSTALL_DIR and AVR_TOOLS_PATH variables to match your setup, then see if you can run make.
That one works for me with Arduino 1.05 and the default Printrbot fork of Marlin. Please let me know if it works and I will see about getting the change merged back to the Printrbot-official source tree.
Postby jeromedayton » 2014-Feb-Wed-15-Feb
Jerome
jeromedayton
Jerome
jeromedayton
