Printrbot Talk Forum • View topic - Can't erase the firmware on Printrboard rev.D (solved)
Postby Tdeagan » 2013-Aug-Thu-21-Aug
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
Quick Change Extruders:
MIC-6 metal bed
Thingiverse Profile:
Tdeagan
Re: Can't erase the firmware on Printrboard rev.D
Postby Tdeagan » 2013-Aug-Fri-21-Aug
This looks to be the same problem as described in this thread .
I hope I don't have to buy a special programmer, but that may be what's next.
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
MIC-6 metal bed
Tdeagan
Postby ei8htohms » 2013-Aug-Sat-01-Aug
On the Rev. D board you have to install a boot jumper (I use an alligator clip actually) to get into bootloader mode. Then remove it and reset when done.
Printrbot GO v.1 - steampunk
Igus DryLin nuts
PB LCD/encoder
GT2 belts
Twin 30mm fans
ei8htohms
Postby Tdeagan » 2013-Aug-Sat-01-Aug
Thanks,
I've had no problem getting into Bootloader mode. I verify with: Bus 005 Device 038: ID 03eb:2ffb Atmel Corp. at90usb AVR DFU bootloader from lsusb per docs. My problem is that the lock bits are set. But I've finally gotten the new firmware burned onto my Bus Pirate to let it talk to avrdude, so I should be able to clear them soon!!
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
MIC-6 metal bed
Tdeagan
Postby ei8htohms » 2013-Aug-Sat-07-Aug
Glad to hear it. So when you said above "When I replace the BOOT jumper...", did you mean "remove.."? Just trying to clarify that our Rev D boards are the same in this regard. Thanks!
Igus DryLin nuts
PB LCD/encoder
GT2 belts
Twin 30mm fans
ei8htohms
Postby Tdeagan » 2013-Aug-Sat-12-Aug
For the Rev. D, the normal operation mode is no jumper. To enter BootLoader, a jumper is placed across the two pins. This is the opposite of all prior boards and causes no end to the amount of documentation grief. It's pretty straightforward in Linux to see the difference with lsusb (Response reads VOTI when in normal operation.) In windows, Flip just wont connect.
I'm struggling with determining how to clear the lock bits, I see lots of docs on how to clear fuses prior to installing a new bootloader. I'm not sure at all that this is the same thing.
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
MIC-6 metal bed
Tdeagan
Postby Tdeagan » 2013-Aug-Sat-16-Aug
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
MIC-6 metal bed
Tdeagan
