Repetier temperature setting
Postby chris » 2013-May-Tue-13-May
I'm trying to increase the extruder temperature on Repetier Host.
Neither the Printer Settings / Default Extruder Temperature
or the Manual Control tab max setting
seem to change what is used during the print job.
I wouldn't think I'd have to reslice - is there some reason I would?
Where else is this set?
chris
Re: Repetier temperature setting
Postby owens » 2013-May-Tue-13-May
The extruder temperature is set by the G-code instructions that you feed to the printer, so yes, you would normally re-slice in order to change it. But you could edit the .gcode file if you wanted, it's just a text file and the commands should be near the beginning; look for M104 (to set the temp) and M109 (to wait for the hot end to warm up). I'd suggest searching the file to make sure they don't appear anywhere else, Slic3r at least allows you to choose different temperatures for different layers, though I think that's off by default.
owens
Postby chris » 2013-May-Tue-17-May
ahhh - I thought that the printer settings would be additional gcode prepended to the drawing gcode - I didn't realize that the gcode was device specific (even moreso than model specific)
chris
Postby fb0160 » 2017-Mar-Wed-07-Mar
How do you export the temperature data? export to excel?
fb0160
Users browsing this forum: Google [Bot] and 2 guests
