Printrbot Talk Forum • View topic - Smalls, Holes too small
Postby Dipstick » 2018-Jan-Sat-15-Jan
I finally got my Smalls working pretty good. One of the problems I am having is that the prints outside diameters are pretty good but the holes are too small. For instance a 8mm hole ends up to be about 7.50 mm.
Any suggestions?
Dipstick
Re: Smalls, Holes too small
Postby RetireeJay » 2018-Jan-Sat-16-Jan
Even the $100,000 commercial printers generate holes smaller than the model calls for. For precise holes, they recommend printing the hole a tiny bit smaller than you want and then boring it out to size.
But with some experimentation, you can develop a procedure to over-size the hole in your model so that it prints pretty close to the size you want. See this post viewtopic.php?f=26&t=4270. There are also several other posts in the forum on this topic.
Postby Mooselake » 2018-Jan-Sat-18-Jan
I keep a set of metric drill bits, and some adjustable reamers, to fix holes.
RJ and I date back to the Kickstarter days, when our bots came as kits with 3D printed parts, and got a lot of experience reaming out holes and filing parts to fit. Things have gotten better (especially the commercially made gears and belt pulleys) but the smaller then desired hole problem remains. an old but still relevant analysis of why this happens. Google "3D printed undersized holes" for an awful lot of discussion of the problem
Postby Dipstick » 2018-Jan-Sun-04-Jan
OK. I will try those.
I do remember though that way back when I had my laser cut Plus that I was able to adjust some things and I got perfect parts and holes. I just don't remember what programs I was using.
Mike
Dipstick
