Printrbot Talk Forum • View topic - current link for flip? atmel now microchip
Postby doug » 2018-Jan-Sun-11-Jan
Looks like Atmel rebranded as Microchip for the new year and decided to hide FLIP. The old link atmel d0t c0m slash tools slash flip d0t aspx (site wouldn't let me post a link in my first post) just redirects to the Microchip home page. Does anyone have a working link to download flip?
thanks
doug
Re: current link for flip? atmel now microchip
Postby RetireeJay » 2018-Jan-Sun-12-Jan
I did some Googling and searching within Microchip's site, and found this page. I can't guarantee it's the right one, but it looks like it should be what you need.
Postby doug » 2018-Jan-Sun-12-Jan
Thanks for looking. That is an old version that does not support the AT90USB1286. For some reason they are not showing 3.4.7.
doug
Postby RetireeJay » 2018-Jan-Sun-17-Jan
I'll see if I can attach a zip of the executable FLIP program installer
Postby doug » 2018-Jan-Sun-17-Jan
PERFECT!
thank you for taking the time to help.
doug
Postby daveculp » 2018-Feb-Fri-20-Feb
I just used that same link and it will work, you just have to install the DFU drivers which are included with the package. Essentially do this:
1. Go to Device Manager
2. Find the "unknown device" or the non-working AT90USB device in the list
3. Right click and "update drivers"
4. Tell device manager that yoiu know where the driver is located.
5. Point it to C:\Program Files\Atmel\FLIP 3.4.1\usb
This page shows how: http://flysight.ca/wiki/index.php/Installing_DFU_driver
daveculp
