Error: pythonw.exe stopped working
Postby mattvl » 2017-Dec-Thu-15-Dec
So I tried printing the Bird Feeder 4.0 (https://www.thingiverse.com/thing:359618) from Thingiverse and about a third of the way through got an error saying "pythonw.exe stopped working". I went through the windows event viewer as well as Cura log file and can't see any obvious things that tell me what the issue is, but I've attached them because, honestly, I've never had to go through either of those before, so I don't really know what to look for.
Any thoughts? I'm currently running Cura 15.04.2 on Windows 7.
Here is the output from the Cura log file:
# Generating comtypes.gen._683BF642_E9CA_4124_BE43_67065B2FA653_0_1_0
# Generating comtypes.gen.TaskbarLib
Listening for engine communications on 49674
...(I cut out some of it because the log file is too long to post. If you need to see the whole thing check here:
https://community.ultimaker.com/topic/2 ... windows-7/)...
Running: C:\Program Files (x86)\Cura_15.04.2\CuraEngine.exe -v -p -s initialSpeedupLayers=4 -s minimalFeedrate=10 -s preSwitchExtruderCode=;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added before the T(n)
-s supportXYDistance=700 -s insetXSpeed=45 -s retractionZHop=0 -s extruderOffset[3].X=0 -s extruderOffset[3].Y=0 -s postSwitchExtruderCode=;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added after the T(n)
-s retractionSpeed=40 -s filamentFlow=100 -s infillOverlap=15 -s inset0Speed=45 -s coolHeadLift=0 -s extrusionWidth=400 -s upSkinCount=10000 -s initialLayerSpeed=35 -s minimalLayerTime=5 -s infillSpeed=45 -s supportExtruder=-1 -s fanSpeedMax=100 -s supportType=1 -s enableCombing=0 -s fanSpeedMin=100 -s supportZDistance=150 -s supportEverywhere=0 -s filamentDiameter=1750 -s initialLayerThickness=300 -s supportAngle=-1 -s fanFullOnLayerNr=2 -s extruderOffset[1].X=0 -s extruderOffset[1].Y=21600 -s layerThickness=200 -s endCode=;End GCode
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F4200 ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
M84 ;steppers off
G90 ;absolute positioning
;CURA_PROFILE_STRING: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
-s minimalExtrusionBeforeRetraction=20 -s retractionMinimalDistance=4000 -s skirtMinLength=200000 -s objectSink=0 -s retractionAmount=1000 -s skinSpeed=45 -s skirtLineCount=5 -s startCode=M190 S70.000000
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
-s skirtDistance=10000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=45 -s fixHorrible=1 -s layer0extrusionWidth=440 -s moveSpeed=70 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=400 -s insetCount=2 -s downSkinCount=10000 -s multiVolumeOverlap=150 -g 49674 -s posx=125000 -s posy=125000 $
Cura_SteamEngine version 15.04.2
Copyright (C) 2014 David Braam
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU Affero General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU Affero General Public License for more details.
You should have received a copy of the GNU Affero General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
Default config 'default.cfg' not used
Reading mesh from socket with 5490186 vertexes
Loaded from disk in 14.243s
Analyzing and optimizing model...
Face counts: 1830062 -> 1828362 99.9%
Vertex counts: 5490186 -> 905913 16.5%
Size: 138.264000 220.168000 143.249000
vMin: 55.868000 14.916000 0.000000
vMax: 194.132000 235.084000 143.249000
vMin: -69.132000 -110.084000 0.000000
vMax: 69.132000 110.084000 143.249000
Matrix: 1.000000 0.000000 0.000000
Matrix: 0.000000 1.000000 0.000000
Matrix: 0.000000 0.000000 1.000000
Optimize model 16.412s
Slicing model...
Layer count: 716
G1 Z+0.5 E-5 X-20 Y-20 F6000 ;move Z up a bit and retract filament even more
M84 ;steppers off
;CURA_PROFILE_STRING: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
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
-s skirtDistance=10000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=45 -s fixHorrible=1 -s layer0extrusionWidth=440 -s moveSpeed=100 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=400 -s insetCount=2 -s downSkinCount=10000 -s multiVolumeOverlap=150 -g 49674 -s posx=125000 -s posy=125000 $
Loaded from disk in 14.336s
['changeZ', '0']
['changeZ', '0']
-s supportXYDistance=700 -s insetXSpeed=50 -s retractionZHop=0 -s extruderOffset[3].X=0 -s extruderOffset[3].Y=0 -s postSwitchExtruderCode=;Switch between the current extruder and the next extruder, when printing with multiple extruders.
-s retractionSpeed=40 -s filamentFlow=100 -s infillOverlap=15 -s inset0Speed=50 -s coolHeadLift=0 -s extrusionWidth=400 -s upSkinCount=10000 -s initialLayerSpeed=35 -s minimalLayerTime=5 -s infillSpeed=50 -s supportExtruder=-1 -s fanSpeedMax=100 -s supportType=1 -s enableCombing=0 -s fanSpeedMin=100 -s supportZDistance=150 -s supportEverywhere=0 -s filamentDiameter=1750 -s initialLayerThickness=300 -s supportAngle=-1 -s fanFullOnLayerNr=2 -s extruderOffset[1].X=0 -s extruderOffset[1].Y=21600 -s layerThickness=200 -s endCode=;End GCode
M84 ;steppers off
;CURA_PROFILE_STRING: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
-s minimalExtrusionBeforeRetraction=20 -s retractionMinimalDistance=4000 -s skirtMinLength=200000 -s objectSink=0 -s retractionAmount=1000 -s skinSpeed=50 -s skirtLineCount=5 -s startCode=M190 S70.000000
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
-s skirtDistance=10000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=50 -s fixHorrible=1 -s layer0extrusionWidth=440 -s moveSpeed=100 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=400 -s insetCount=2 -s downSkinCount=10000 -s multiVolumeOverlap=150 -g 49674 -s posx=125000 -s posy=125000 $
G1 Z+0.5 E-5 X-20 Y-20 F5100 ;move Z up a bit and retract filament even more
M84 ;steppers off
;CURA_PROFILE_STRING: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
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
-s skirtDistance=10000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=50 -s fixHorrible=1 -s layer0extrusionWidth=440 -s moveSpeed=85 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=400 -s insetCount=2 -s downSkinCount=10000 -s multiVolumeOverlap=150 -g 49674 -s posx=125000 -s posy=125000 $
Loaded from disk in 14.290s
M84 ;steppers off
;CURA_PROFILE_STRING:eNrtWktv20YQvhJCf8QeEzRWSUqK7Qi8JLV9SYoAdtHEF2JFrsRtSC6xu7QsG/rv/Xb5ECVTqdMabR7ywTI/zszOznzzAOSUrpgME8YXiQ7coe8saZqGOuHRp5wpBejEkUxLGmku8pDldJay4EqWzFEi5XGYWgPbCnMOGzHLFderwHNdJxd3dykLFb9jEBg7heS5DlXBWBxM3PpRs6xgkupSssD3elA/6AFHfeC4D5y04IzFW6cdu44qi0JIHfwmcuYUKdVzIbOQxglTuHcF1zJhXNI0ZLdalvbda6ETZ8kLFmqxZDI4p6liHSC8EWmZscCbOELcIQoJZ2lciyFUNGPwKeb41FD3hseTh7C5+wNw1AeO+8BJF5ynYmnSMnS7qa2yMd5BaSbKXAfjLmbvX7/wXg4n3XcZz0M83LB0WycS2Yzni4o52/I82wonHPC7EokoDObMhNYi22LayLHsc8Mlj3USzqEhEEBwR8z+ZBEYxvNPuLm4YTKlhXUcakhE5WJ955NJY7wic4WOJg7PLZOrZ+ODpTyVjHYwnium3V3gtgNEQqQ2MHWtcJABKaZNOcV1PX3iIFfKc4ZomdhOamhBC6SrfmgClrJ8oZPAR3UZS/MSjrZl/NJilQdeLWGfwozeWqT1aQ4UZcDMCRZMGEVV87muGVqVuUYWOlVfxatCbIzqEBuSo6y4JR3qDFXEwiqMtXpdQ3pVsOAt7qpaiOYLtJaXbS2G1nDl26QFb1cgtdI0j1gwPG7huw1qE6wKLmlq+k19C54V6ECZiBtkBi+70fbBezpHgKlc8DyYDOtnK6IKGhn6jhp0RhXb4eIGNyqWkijmWh5th0kQdFvJP959u1E1fdK+pFyCASH6smVTBzMW/ApQZa1vKKaCHbTvzFZj68Q5v0XFScnBy7DMbQswAwHpCmmT7/0is7atdWUQElGwPJxxrfoEUPxmWNwgzprrKDGRrsSKtEQykCFQaBE0ZR0xE6/wNjjydqAVoJ/AA6mHi8jk+sI/IR9c8tEl1+7g4tQnZ/jwTx2Wx7XE9CyPycUb/Dl457ljcumSvp+p7VAxkwQFgqOImM+hMHb3Kli5mGDYdFTIMz4nK1GSBA2IcP0cTnnkET9TyTCVECNSCMxVRB1RGlx45OzII+cj1/0bZdtPiU4YaeYAoQQJIVWRElPxsGglqnH9gmhBcCoDpYkSGYP/9nUhwSTMTXP69c/ucAIfJuTDkY84m1/n9932uibTDN2BXJOyqI+kiHjjUesNu2E5yYQx2+bs8xGxZj/88tH4iVZGkFOFPqVewFvrqGllhCsiSt34vqSrwbuT8X6jSrMCHUzZ/F6c7vdhSmfohaXeTsj0vpACdzJUxq6xWDuWjX5DtsuURyAE1a/IfUxXa/NbM3yYqbAeTF9TxSOCAWKSoV6Rt6aeSdXYoZJ21rU1+QN1B5n77Z1tTc7ROAF31zCYfm92H2LOwbt6O6oOPW9ygEqNK8VqU6iG/DrrQMvq7EVHKxJKd7XMM6y+8xC9y/velQuk+D3HTmD1kT4ax6YqUCLL3FZMR5aYDmXMmeK8f7DWfdZUr5lTcuX1WfL/kSn33zt14XsbUqMuwIAbmpZMdQnYzzf4cLyhLphGllwnVZ3TvCLxppz2lowVunY7dXX9UATV7mEs7qlv2xnqxZnE5p7eJMsGV3u62/RyaVq9OcVo+mgJTYet+3SPzh2TlXgtGpNqDTK+nWMVImee29u1iedmmekBZt0huE/06ctPIXRBeb456+i+fyleD67cR116zqXS39K1txOPloLGarlvJkeG3kMXmBI5efvmV6IiyVgOgnrH5H0tMxwOzeT194zeK/cLp6/R8Q4T+zCxn35ijw4T+zCxf8yJ7f+IE/uwphzWlJ01ZfR/rilGxz+sNofV5ulXm/FhtfmqVhv/6Vabw5b0n21Jo0fNzjGc/o4WhsethqPv69KH1fCwGu6shuNvbTU0OqPDOnlYJ592nay/fe9+49qCm69Yq38s2BKySEdCMszYiA0jdRM4SELVZs5qXrYLa9V8ZkwvUZn20lEppQ1xQ2GTAJtoIC36giwTKLSVbpeJrEw1L9K2XUg1HEyvEgTVnGaCi/XGstyyyBi9epY/dxAT/TX5R+emABv3/gIhodhS
-s minimalExtrusionBeforeRetraction=20 -s retractionMinimalDistance=4000 -s skirtMinLength=200000 -s objectSink=0 -s retractionAmount=4000 -s skinSpeed=50 -s skirtLineCount=5 -s startCode=M190 S70.000000
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
Loaded from disk in 14.227s
Optimize model 16.256s
Slicing model...
Layer count: 716
Sliced model in 24.726s
Generating support map...
Generating layer parts...
Generated layer parts in 13.057s
Generated inset in 134.863s
Generated up/down skin in 87.688s
['changeZ', '0']
['changeZ', '0']
-s retractionSpeed=40 -s filamentFlow=100 -s infillOverlap=15 -s inset0Speed=45 -s coolHeadLift=0 -s extrusionWidth=400 -s upSkinCount=3 -s initialLayerSpeed=35 -s minimalLayerTime=5 -s infillSpeed=45 -s supportExtruder=-1 -s fanSpeedMax=100 -s supportType=1 -s enableCombing=0 -s fanSpeedMin=100 -s supportZDistance=150 -s supportEverywhere=0 -s filamentDiameter=1750 -s initialLayerThickness=300 -s supportAngle=-1 -s fanFullOnLayerNr=2 -s extruderOffset[1].X=0 -s extruderOffset[1].Y=21600 -s layerThickness=198 -s endCode=;End GCode
M84 ;steppers off
;CURA_PROFILE_STRING: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
-s minimalExtrusionBeforeRetraction=20 -s retractionMinimalDistance=4000 -s skirtMinLength=150000 -s objectSink=0 -s retractionAmount=1000 -s skinSpeed=45 -s skirtLineCount=2 -s startCode=M190 S70.000000
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
-s skirtDistance=3000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=45 -s fixHorrible=1 -s layer0extrusionWidth=400 -s moveSpeed=70 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=2666 -s insetCount=2 -s downSkinCount=3 -s multiVolumeOverlap=150 -g 49674 -s posx=125000 -s posy=125000 $
M84 ;steppers off
;CURA_PROFILE_STRING:eNrtWktv20YQvhJCf8QeEzRWSUqK4wi8JLV9SYoAdtHEF2JFrsStSS6xu7QsG/rv/Xb5ECVTqdMabR7ywTI/zszOznzzAOSUrpgME8YXiQ7coe8saZqGOuHRdc6UAvTKkUxLGmku8pDldJay4FKWzFEi5XGYWgPbCnMOGzHLFderwHNdJxd3dykLFb9jEBg7heS5DlXBWByMJ/WjZlnBJNWlZIHvuQ9RP+gBR33guA+ctOCMxVunHbuOKotCSB38JnLmFCnVcyGzkMYJU7h3BdcyYVzSNGS3Wpb23RuhE2fJCxZqsWQyOKOpYh0gvBFpmbHAmzhC3CEKCWdpXIshVDRj8Cnm+NRQ94bHk4ewufsDcNQHjvvASRecp2Jp0jJ0u6mts7GD0kyUuQ68Lmbv37x4OZx032U8D/Fww9Jg3MUjkc14vqiYsy3Ps61wwgG/K5GIwmDOTGgtsi2mjRzLPjdc8lgn4RwaQlrCidmfLALDeH6Nm4sbJlNaWMehhkRULtZ3Pm6NV2Su0NHE4bllcvVsfLCUp5LRDsZzxbS7C9x2gEiI1AamrhUOMiDFtCmnuK6naw5ypTxniJaJrV9DC1oEI3O6fWoilrJ8oROwyhxhjM1L+NpW8kuLVU6YiLRPYUZvLdK6NQeKSgBDazBhFIXN57omaVXpGonoFH4VsgqxYaqjbHiOyuKWdyg1FBILq0jW6nUZ6VXBgne4rmohmi/QXV625Rhaw5Vvkxa8XYHXStM8YsHwuIXvNqjNsSq4pKlpOfUteFagCWUibpAZvNwKOKhP5wgxlQueB5Nh/WxFVEEjw+BRg86oYjt03OBGxbIS9VzLo/MwCY5uK/nHu283qqZV2peUS5AgRGu2hOpgxoJfAaqs9Q3LVLCD9p3ZamydOOe3KDopOagZlrntAmYmIF0hbfK9X2TWdrauDEIiCpaHM65VnwDq38yLG8RZcx0lJtKVWJGWSAYyBAotgqayI2biFd4GR94OtAL0E3gg9XARmVyf+6/IR5d8csmVOzg/8ckpPvwTh+VxLTE9zWNy/hZ/Dt577phcuKTvZ2qbVMwkQYHgKCLmcyiM3b0KVi4mmDcdFfKMz8lKlCRBDyJcP4dTHnnEz1QyDCbEiBQCoxVRR5QG5x45PfLI2ch1/0bZtlSiE0aaUUAoQUJIVaTEVDwsWolqYr8gWhCcykBpokTG4L99XUgwCaPTnH71szucwIcJ+XjkI87m19l9t8OuyTRDdyBXpCzqIyki3njUesNuWE4yYcy2Oft8RKzZj798Mn6ilRHkVKFPqRfw1jpqWhnhiohSN74v6Wrw/tV4v1GlWYEOpmx+z0/2+zClM/TCUm8nZHpfSIE7GSpj3VisHctGvyHbRcojEILq1+Q+pqu1+a0ZPsxgWA+mb6jiEcEMMclQr8k7U8+kauxQSTsb25r8gbqDzP322rYmZ2icgLubGEx/MOsPMefgXb0gVYeeNTlApcaVYrUsVHN+nXWgZXX2oqMVCaW7WuYZVt97iN7Ffe/WBVL8nmMtsPpIH41jUxUokWVuK6YjS0yHMuZMcd4/2Ow+a6rXzAm59Pos+f/IlPvvnTr3vQ2pURdgwA1NS6a6BOznG3w43lAXTCNLrpOqzmlekXhTTntLxgpduZ26unoogmr3MBb31LftDPXuTGJzT2+SZYPLPd1terE0rd6cYjR9tISmw9Z9ukfnjslKvBaNSbUIGd/OfPTAU8/t7drEc7PM9ACz7hDcJ7r+8lMIXVCeb846uu/fi9eDS/dRl55zqfS3dO3txKOloLFa7pvJkaH30AWmRE7evf2VqEgyloOg3jH5UMsMh0Mzef09o/fS/cLpa3S8w8Q+TOynn9ijw8Q+TOwfc2L7P+LEPqwphzVlZ00Z/Z9ritHxD6vNYbV5+tVmfFhtvqrVxn+61eawJf1nW9LoUbNzDKe/o4Xhcavh6Pu69GE1PKyGO6vh+FtbDY3O6LBOHtbJp10n62/fu9+4tuDmK9bqHwu2hCzSkZAMMzZiw0jdBA6SULWZ05qX7cJaNZ8Z00tUpr10VEppQ9xQ2CTAJhpIi74gywQKbaXbZSIrU82LtG0XUg0H08sEQTWnmeBivbEstywyRi+f5c8dxER/Tf7RuSnAxr2/AH1J2Ns=
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
-s skirtDistance=3000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=45 -s fixHorrible=1 -s layer0extrusionWidth=400 -s moveSpeed=70 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=400 -s insetCount=2 -s downSkinCount=10000 -s multiVolumeOverlap=150 -g 49674 -s posx=125000 -s posy=125000 $
Loaded from disk in 14.196s
M84 ;steppers off
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
Loaded from disk in 14.461s
M84 ;steppers off
;CURA_PROFILE_STRING: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
-s minimalExtrusionBeforeRetraction=20 -s retractionMinimalDistance=4000 -s skirtMinLength=150000 -s objectSink=0 -s retractionAmount=1000 -s skinSpeed=45 -s skirtLineCount=5 -s startCode=M190 S70.000000
M109 S210.000000
G28 X0 Y0 Z0
G92 E0
G29
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '0']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '1']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '2']
['changeZ', '3']
['changeZ', '3']
['changeZ', '3']
['changeZ', '3']
['changeZ', '3']
['changeZ', '4']
['changeZ', '4']
['changeZ', '4']
['changeZ', '4']
['changeZ', '4']
['changeZ', '5']
['changeZ', '5']
['changeZ', '5']
['changeZ', '5']
['changeZ', '5']
['changeZ', '6']
['changeZ', '6']
['changeZ', '6']
['changeZ', '6']
['changeZ', '6']
['changeZ', '7']
['changeZ', '7']
['changeZ', '7']
['changeZ', '7']
['changeZ', '7']
['changeZ', '8']
['changeZ', '8']
['changeZ', '8']
['changeZ', '8']
['changeZ', '8']
['changeZ', '9']
['changeZ', '9']
['changeZ', '9']
['changeZ', '9']
['changeZ', '9']
['changeZ', '10']
['changeZ', '10']
['changeZ', '10']
['changeZ', '10']
['changeZ', '10']
['changeZ', '11']
['changeZ', '11']
['changeZ', '11']
['changeZ', '11']
['changeZ', '11']
['changeZ', '12']
['changeZ', '12']
['changeZ', '12']
['changeZ', '12']
['changeZ', '12']
['changeZ', '13']
['changeZ', '13']
['changeZ', '13']
['changeZ', '13']
['changeZ', '13']
['changeZ', '14']
['changeZ', '14']
['changeZ', '14']
['changeZ', '14']
['changeZ', '14']
['changeZ', '15']
['changeZ', '15']
['changeZ', '15']
['changeZ', '15']
['changeZ', '15']
['changeZ', '16']
['changeZ', '16']
['changeZ', '16']
['changeZ', '16']
['changeZ', '16']
['changeZ', '17']
['changeZ', '17']
['changeZ', '17']
['changeZ', '17']
['changeZ', '17']
['changeZ', '18']
['changeZ', '18']
['changeZ', '18']
['changeZ', '18']
['changeZ', '18']
['changeZ', '19']
['changeZ', '19']
['changeZ', '19']
['changeZ', '19']
['changeZ', '19']
['changeZ', '20']
['changeZ', '20']
['changeZ', '20']
['changeZ', '20']
['changeZ', '20']
['changeZ', '21']
['changeZ', '21']
['changeZ', '21']
['changeZ', '21']
['changeZ', '21']
['changeZ', '22']
['changeZ', '22']
['changeZ', '22']
['changeZ', '22']
['changeZ', '22']
['changeZ', '23']
['changeZ', '23']
['changeZ', '23']
['changeZ', '23']
['changeZ', '23']
['changeZ', '24']
['changeZ', '24']
['changeZ', '24']
['changeZ', '24']
['changeZ', '24']
['changeZ', '25']
['changeZ', '25']
['changeZ', '25']
['changeZ', '25']
['changeZ', '25']
['chang
Thoughts?
mattvl
