Metal Plus: Does Autolevel Cycle, but does not autolevel
Postby DaedalusMinor » 2017-Dec-Wed-23-Dec
So I've had this Printrbot Metal Plus (1504) for about three years now, and after trying to print something again, it changed its pre-print setup. It checked the 3 points like usual, but then it lifted a few mm off the bed and then started the print, as opposed to just going straight to the print place and compensating in lifting the extruder in the z-axis.
I've checked the autolevel probe and it seems to detect metal anywhere, and it does not affect the probe on whether I move the wires around to check for any disconnection. No change was made to the gcode prior to the print where it all started.
I've tried reflashing the firmware on the REV F5 board, but came out with the same result. Although Printrbot's instructions do seem rather outdated.
Is this necessarily a problem with software, such as outdated firmware? If so, is there some fool-safe guide on how to update it? Or is it hardware?
Please let me know if you have encountered the same problem and how you fixed it.
DaedalusMinor
Re: Metal Plus: Does Autolevel Cycle, but does not autolevel
Postby RetireeJay » 2017-Dec-Thu-07-Dec
It's almost certainly not a problem with the firmware, and I hope that in re-flashing your board you were able to use the exact same firmware that you were using originally.
Use the M119 command to check the status of the sensor as seen by the board. If it's always triggered (or never triggered) then you probably have a broken wire between the board and the probe, or the probe itself is bad. It's pretty common for the wires between the probe and the board to develop internal breaks due to "fatigue" - bending back and forth at a point. The wires can be spliced if you're handy with a soldering gun and heat-shrink tubing, or you can replace the whole probe including the wires attached.
Postby DaedalusMinor » 2017-Dec-Fri-10-Dec
Although that wasn’t the issue, I did look at the probe and replace it with a new one. No issues now except from a grinding noise across the x axis, and it’s probably electrical because there are no sounds when sliding by hand. Anyways thank you for helping narrowing down the problems!
DaedalusMinor
