Y axis zeroing off the bed
Postby mattvl » 2017-Nov-Wed-23-Nov
So I just installed a new stepper motor for my extruder and my Y axis is now zeroing half on half off the bed. When it goes to the other side during bed levelling, in the pre print run through, it goes too far out across the X axis so that the probe goes off of the bed and the hot end tip dives into the board. I tried adjusting the M210/M211/M212 settings in Cura, to no avail. Any ideas?
mattvl
Re: Y axis zeroing off the bed
Postby RetireeJay » 2017-Nov-Thu-10-Nov
Is the stepper motor the only thing you changed since the last time the printer was working? From some of your other posts, I wonder if you have a new Printrboard or you may have flashed new firmware onto your board. The Extruder stepper motor change by itself would not cause the Y axis to go bonkers. You need to start with examining the contents of EEPROM using M503.
Postby mattvl » 2017-Nov-Thu-18-Nov
You're right, I had changed the printrboard as well awhile back, but never got the extruder going again since. I thought I had checked the homing, but it's been long enough that I can't be sure. I tried using the M501 command to adjust the min/max positions and the home offsets, but it didn't change anything. Here are my M503 results:
< echo:Steps per unit:
< echo: M92 X80.00 Y80.00 Z2020.00 E96.00
< echo: M203 X125.00 Y125.00 Z5.00 E14.00
< echo:Home offset (mm):
< echo:PID settings:
< echo:Min position (mm):
< echo:Max position (mm):
< echo: M211 X250.00 Y250.00 Z254.00
< echo:Bed probe offset (mm):
< echo: M212 X0.00 Y0.00 Z0.60
Any ideas?
mattvl
Postby RetireeJay » 2017-Nov-Thu-19-Nov
I don't see any smoking guns there. The steps/mm on all axes look reasonable, the minimums are all zero and the maxima are 250 or 254mm, which corresponds to the build size of the Metal Plus at 10" on every axis.
What happens when you tell the printer to go to Y home? Does it successfully find the "end stop" switch?
Postby mattvl » 2017-Nov-Thu-19-Nov
It looks like it finds the end stop switch without a problem as there isn't any grinding. It just bumps the switch and then backs up, as per usual. However, it doesn't back all the way onto the bed. It ends up sitting half on and half off.
As an added note, I believe I also changed the extruder carriage since it was last going. Printrbot released a new one that reduces cable bending...I don't really see how that could affect the homing as the measurements appear to be the same, but it's a little hard to compare as the new one is connected to the actual printer right now.
mattvl
Postby RetireeJay » 2017-Nov-Thu-21-Nov
I think I'd look at the physical location of the Y zeroing switch and also the part which touches the switch to activate it. On the old machines, Printrbot used an adjustable screw to determine exactly where motion along each axis would acutate its respective switch.
Postby mattvl » 2017-Dec-Sat-07-Dec
So upon closer inspection the lever arm actuator was bent perfectly in half allowing it to work, but a couple mm later than usual. It looks like I'm going to have to buy a new one of those as well. Are there any specs on the switch? I'd like to purchase one locally, if at all possible.
mattvl
Postby RetireeJay » 2017-Dec-Sat-14-Dec
Needle nose pliers to bend it back to nominal shape? Adjust the screw (if there is one) that fine-tunes the actuation point?
Look on the switch for a part number and Google it?
Postby mattvl » 2017-Dec-Sat-15-Dec
I'd already tried bending it back but it just fell right off. It doesn't have any adjustment screw and the only thing legible on the side is "SS" which I googled before and just got the companies list of switches but nothing specific to the model number. I'll probably just bring it in to a local shop and see if they can give me an equivalent one.
mattvl
Postby RetireeJay » 2017-Dec-Sat-20-Dec
Generically, these are called "microswitches" because they actuate with a pretty small motion of the nub that the lever pushes on.
The key parameters for you to look for are:
(1) physical size - it has to fit
(2) It should be either a "Normally Closed" SPST (Single Pole, Single Throw) or, preferably, a SPDT (Single Pole Double Throw). The latter gives you options just in case the logic of the endstop switch on the Printrboard has been changed for some reason.
The voltage rating and current rating are pretty much irrelevant, because any switch you find in this physical size will be able to handle 12V at a few milliamps.
I'm sure you'll find a huge selection at DigiKey.com, which is where Printrbot gets most of their electronic parts.
Postby mattvl » 2017-Dec-Thu-12-Dec
So I picked up a couple here in Canada with the same specs, but also one from Printrbot just in case. The former were super cheap, so I figured it would be good to have a couple extra kicking around. Anyway, I installed the new limit switch and it's still doing the exact same thing. Is it possible to change the Y homing coordinates to make the auto-levelling probe on top of the bed rather than just off the side of it?
EDIT: Wellllllll after reading through an assembly guide, I've discovered that the arm on the limit switch is supposed to bent at 90 degrees to be activated earlier (see attached). So...problem solved! Thanks for your help!
https://drive.google.com/file/d/0B9oj0J ... JEQkE/view
mattvl
