Printrbot Talk Forum • View topic - End G-Code final head position
Postby MileHigh3DII » 2017-Mar-Sun-18-Mar
I have a PB+ dual head with 'home' in the rear left corner. At the end of my print, the head finishes up, heads to the back left corner but once it get there, it heads back tot the front of the print bed- about where it goes after I run the G29 code to level the bed.
I don't see why it goes back to the front, plus it 'grinds' for a split second when it gets there, probably because it is a software stop, not a hardware limited one.
Here is my ending G-Code:
G1 X107.343 Y99.520 E915.40526
M107
G1 F2400 E914.90526
G0 F9000 X107.343 Y99.520 Z68.000
;End GCode
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
M84 ;steppers off
G90 ;absolute positioning
Here is my start G-code:
G21
M107 ;start with the fan off
G28 Z0 ;move Z to min endstops
G29
G1 Z15.0 F9000 ;move the platform down 15mm
G1 F200 E3 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F9000
;Layer count: 629
;LAYER:0
M106 S226
G0 F9000 X92.918 Y93.884 Z0.200
;TYPE:SKIRT
G1 F1200 X94.877 Y92.285 E0.09252
MileHigh3DII
Re: End G-Code final head position
Postby RetireeJay » 2017-Mar-Sun-19-Mar
Postby MileHigh3DII » 2017-Mar-Mon-01-Mar
Nope that wasn't it???
Actually, that didn't seem to do anything. It still goes to the back left corner and then comes in a straight line to 2/3 to the right side all the way forward.
Is it something outside of this g- code? Something set in the firmware of something?
MileHigh3DII
Postby Mooselake » 2017-Mar-Mon-09-Mar
The G28 home command in your end gcode is why it moves to the home position. Not sure why it moves after that, but try moving the G90 before the home command so it's not homing in relative mode.
Has it always done this with this gcode, or is it something new?
Postby RetireeJay » 2017-Mar-Mon-09-Mar
Postby Mooselake » 2017-Mar-Mon-11-Mar
The firmware implements soft limits, i.e. it won't let you move outside the configured limits of each axis as long as you haven't lost position by missed steps. It should never grind unless it's not where it thinks it is or when homing with a malfunctioning switch.
We've seen a lot of probes with open wires, which the firmware interprets as a triggered home switch. I wonder if your errant axis has a shorted switch, which would never trigger and might give the behavior you're seeing as it goes a way past where the switch should be and then gives up. The home switches use closed (current passing) contacts for untriggered so a broken wire will look like a triggered switch, a holdover from their CNC roots. Inversely a shorted switch will always appear untriggered. There are no limit switches on reprap devices, they're both lightweight and have low powered motors. When you're slinging tones of cast iron around limit switches can be machine and actual life savers, but having a 3D printer carriage doing the full tilt boogie slam into the stops won't hurt much, even if you stick a finger in there.
Use the M119 command to display the current endstop status. Check it with the problematic axis off the home switch, then use the manual controls to get it as close as you can and then give it a little shove so it clicks, and check it again. Or you could just use something to reach in there and push it, but the check it with the machine will also help detect an obstruction that prevents it from closing. Perhaps there's a piece of Dorito (or something else) under the switch? An loose piece of plastic that keeps the machine from getting close enough to actuate the switch.
