Repetier Host Temperature Graphs
Postby fb0160 » 2017-Mar-Wed-07-Mar
How do you export temperature data to excel?
Also how do you display multiple extruders on the one graph?
fb0160
Re: Repetier Host Temperature Graphs
Postby Mooselake » 2017-Mar-Wed-08-Mar
Please only post your questions in one place. It's easy to find all unread posts, and that's how most of us read the forum.
Thanks
Postby RetireeJay » 2017-Mar-Wed-08-Mar
There is a log file (Repetier.log) that Repetier creates new each time you start it up (which deletes the old log file), but doing a quick check, the temperature data seems to be absent from my log file. Maybe there's a setting somewhere in Repetier to enable recording the temperature to the log file. But even if you did that, the log file would still also be full of other data also.
This sounds like a possibly useful, but not really crucial, addition to the program. You might suggest it to the developer. Or dive into the code and create it yourself. Excel can import data that's in the form of a text file, with comma-separated values.
