Help printer no longer connects to pc
Postby carre55 » 2016-Oct-Mon-09-Oct
Hi folks I've had a break from fiddling with my printrbot metal plus for a couple of months and thought I'd get back into it now winter approaches and can not connect via USB just keeps saying closed after trying any ideas what I need to focus on to get back into it is it because cura is a newer version then the included download
Thanks paul
carre55
Re: Help printer no longer connects to pc
Postby Mooselake » 2016-Oct-Mon-09-Oct
Make sure you're using the correct com port. Cura might include an automatic selection option (Repetier-Host does), or you might need to try until you find the right one. The Windows Device Manager (hold down the Windows key, then type X and find it in the list) should also help ID the port.
Do you get the ta-dings when you plug/unplug the cable?
Postby carre55 » 2016-Oct-Mon-10-Oct
No no noise tried several USB slots tried auto and the other settings
carre55
Postby RetireeJay » 2016-Oct-Mon-10-Oct
Is the green light on the Printrboard lit up? It doesn't tell you very much, because it's not under firmware control, but at least it does tell you that there is power on the board.
Do you have anything else that you can connect to your computer using the same USB cable - to check the cable's integrity? When you connect anything else to the computer via USB, do you hear the "ba-ding"? If you bring up the Device Manager screen, does it "refresh" itself when you plug in the Printrboard? If so, try to find exactly what shows up. You might need to run the "teensy" COM port installer again; sometimes Windows updates make the computer forget that it's been told to treat the Printrboard as a virtual COM port connected on a USB port.
Is the USB cable plugged into the board all the way? Is the USB connector on the board secure and not pulling away from the board?
Postby carre55 » 2016-Oct-Mon-13-Oct
At work so can't try till 2morrow
However thanks for the pointers as where to start
Regards paul
carre55
Postby carre55 » 2016-Oct-Tue-10-Oct
Thanks guys turns out one of my power pack plugs was duff and when I replugged it all back together (different plug it works as should
regards
Paul
carre55
