Printrbot Talk Forum • View topic - Can't pronterface to board
Newbie talk about software tools, drivers, etc
Postby 3DSheffield » 2013-Apr-Tue-16-Apr
I have a printrbot LC. I have made it from files from thingiverse. I have a revision E printrboard. Windows XP instals the device and recognises it says it is installed correctly and functioning (serial install service pack 3.5 etc) but I cannot connect pronterface.
says connecting but doesn't
have set baud rate and see either COM3 or 4 depending on socket used.
PC is fairly old is this an XP problem or have I connected up something wrong.
Also there ared different flavours of USB odes this matter.
I am thinking of replacing with a Win7 laptop
Again does USB 3 work with this board
board was shipped assembled tested flashed with marlin LED lights under USB power
Have unsoldered USB power for now (LED lights under external ATX)
I have tried searching forums to now avail is there something obvious or a way to fault find
Many thanks
dave
3DSheffield
Re: Can't pronterface to board
Postby RetireeJay » 2013-Apr-Tue-16-Apr
Did you install the USB Serial driver?
http://pjrc.com/teensy/serial_install.ex
I have no idea why this has been dropped from the Getting Started Guide. It was there in the older version of the guide that I used in January. Now I wish I'd downloaded the guide... :(
Anyway, I've connected both an XP and a Win-7 computer to my 'bot with no problem.
USB3 is supposed to be completely backwards-compatible with lower-numbered versions, so I doubt that's a problem.
When you plug in your 'bot, then it should show up in Device Manager, something like this (from a Windows-7 screen shot). It's on the last line here, as "USB Serial (Communication Class, Abstract Control Model) (COM30).
So in order to use it, I set the COM port in Repetier (or Pronterface) to 30. You will probably see a different COM port on your machine. Mine was different on the XP computer than on this W-7 computer.
Postby PxT » 2013-Apr-Tue-16-Apr
Postby RetireeJay » 2013-Apr-Tue-19-Apr
Thanks, PxT! I've got it saved now.
Postby 3DSheffield » 2013-May-Sat-13-May
yes i installed the serial driver as administrator also correct COM port selected in pronterface and correct baud rate.
On a win 7 laptop I get the following in the pronterface .exe console. Com 5 is the port listed in device manager. Says device is abstract class control and fuctioning correctly I get one constant green LED on the printrboard (bought from a 3rd party fleabay seller in denmark)
Exception AttributeError: "'NoneType' object has no attribute 'stdout'" in <bound method Tee.__del__ of <__main__.Tee object at 0x03922FD0>> ignored
Traceback (most recent call last):
File "pronterface.py", line 1566, in connect
File "printcore.pyc", line 76, in connect
File "serial\serialwin32.pyc", line 30, in __init__
File "serial\serialutil.pyc", line 260, in __init__
File "serial\serialwin32.pyc", line 56, in open
serial.serialutil.SerialException: could not open port COM5: [Error 5] Access is denied.
Anything obvious?
Many thanks
Dave
3DSheffield
Postby JoeKneale » 2013-Oct-Sat-08-Oct
The tip about looking up the COM# in the device manager saved my day. For whatever reason mine was on COM5, I couldnt understand why Repetier couldn't connect -- this solved it!
Thanks you!
JoeKneale
Return to Newbie talk
