There are some things you can do to help design out warping and layer separation as well, depending on the part.
When a part is being printed, each layer is put down hot and then contracts as it cools. There is some time between deposition of each layer in a particular location, because the print head must move all around to get every position in the layer. This means that each layer ends up tugging "inward" on the layer below it. With enough layers pulling each other, it's not surprising that the bonds between lower layers get overloaded and the layers start to peel apart. While making stronger bonds (via higher temp) and reducing the thermal differences between layers (via heated print bed / environment) can help, there are design characteristics which can also help.
Based on my comments above, one can deduce that longer layers would be more subject to peeling apart than shorter layers, as there is more distance over which cooling-related shrinking can occur. Also, the amount of time between the deposition of subsequent layers can influence the degree to which each layer tugs on the one below it - if they all came out at the same temperature at one time, then while cooling they would all stay at about the same length as each other and there would be very little "peeling force" to help separate the layers. It may be possible to print your part in another orientation, such that each layer takes less time to print before the next is started - a "tall and narrow" setup instead of "short and fat".
Alternatively, one can incorporate "break points" within layers to help keep the peeling force to a minimum. The picture below shows a basket/box that I printed to hold trash bags behind my trash can. At the outset I was printing the part with solid walls...and I ran into significant layer separation problems. I terminated the print early and used a knife to give myself a flat-ish top surface ... but I found that the box was not deep enough to accomplish the intended purpose. I revised the part to include breaks in the walls, and then printed just an upper section which I attached to the lower section with superglue. As you can see in the pic, there is essentially no layer separation in the upper part vs. very significant separation in the lower part, despite the remainder of the printer settings remaining fixed (same extrude temp, same bed temp, same room, same bed prep, etc).
