Old firmware for Rev D
Newbie talk about software tools, drivers, etc
Postby aerogeek » 2018-Jan-Mon-16-Jan
hi all,
it looks like i have corrupted the firmware on my printrbot plus V1/LC by shutting down mid running or heating up. i need to re-flash it but cant find the legacy firmware anymore (obviously my bot is too old :( now for PB to support.
Does anyone have a working version of the firmware of for the printrbot rev D? if not what could be a good work around? is it feasible to download latest marlin and select correct options for printrbot plus with no autoleveling etc?
aerogeek
Re: Old firmware for Rev D
Postby RetireeJay » 2018-Jan-Mon-16-Jan
See my answer in your other post.
Return to Newbie talk
