Printrbot Talk Forum • View topic - micro sd to sd card extension
Postby New Passion » 2015-Mar-Sun-12-Mar
Hi,
I have been looking at a way to print without my computer tethered to the printer. I know you can buy the lcd, but I wanted to try the micro sd slot, but it is very inconvenient to get to. I seen an extension cable that plugs into the micro sd slot on the printer and allows you to plug in a standard sd card in the other end. Here is a link to one, there are many more out there. http://www.ebay.com/itm/Micro-SD-Male-t ... 258d54e1cb
Will this work ??
New Passion
Re: micro sd to sd card extension
Postby musk » 2015-Mar-Sun-12-Mar
I've tried one that looked identical to that ebay link, but it didn't work:
http://www.aliexpress.com/snapshot/6192 ... 3589083397
But I've got three of these and they work great:
http://www.aliexpress.com/item/SD-to-TF ... 61833.html
Printrbot Metal Plus (2x)
Printrbot Simple Metal (2x)
musk
Postby New Passion » 2015-Mar-Sun-13-Mar
Thanks musk, I just ordered one.
New Passion
Postby thawkins » 2015-Mar-Sun-13-Mar
Postby 2Mylent » 2015-Mar-Sun-17-Mar
Avec métalliques simples Printrbot pour exécution automatique SD Card: le nom de fichier est impérativement "auto0.g"
Source des informations: Printrbot.com
Printrbot Simle Metal + Upgrade Heatbed / Upgrade E3D v6 / Simplify3D / Win7 64bits
FRANCE
2Mylent
Postby New Passion » 2015-Mar-Mon-22-Mar
Is there a certain sd card that you have to use ie. 2 GB or will a 32GB or 64GB work, and do I have to format the card to fat32 or some other format ?? I understand I have to put the file in the root directory and name it auto0.gcode. Thanks for the help.
New Passion
Postby thawkins » 2015-Mar-Tue-01-Mar
Postby New Passion » 2015-Mar-Tue-11-Mar
Thanks thawkins. When you say reset the board, are you referring to the little black push button on the board, and do I reset it with the power on. I am not sure what you mean when you say powercycle it. If I turned the power supply off after the print finished would this make Marlin reset so I could use auto0.gcode on the next print or would I still have to push the black button to reset the board, if that is the reset switch ( I am assuming it is). Thanks for your patience for a newbie.
New Passion
Postby 2Mylent » 2015-Mar-Tue-12-Mar
FRANCE
2Mylent
Postby orangefurball » 2015-Mar-Tue-17-Mar
Thingybot Delta Printer
http://www.thingybot3d.com
orangefurball
Laser scintillater
Postby New Passion » 2015-Mar-Tue-17-Mar
Thanks orangefurball, I have some sd cards laying around for my digital camera, they vary from 2 GB to 4 GB to 16 GB. I think I will wait until my micro sd to sd extension comes in that I ordered and go from there, but still not sure about the reset of the board after printing that thawkins mentioned earlier.
New Passion
Postby orangefurball » 2015-Mar-Tue-18-Mar
orangefurball
Laser scintillater
Postby New Passion » 2015-Mar-Tue-19-Mar
Ok I now I understand. Thanks for all your help
New Passion
Postby deandzines » 2017-Nov-Sat-12-Nov
TEM Products sells them on Tindie. Do a search for "microSD extension cord"
They are small microSD-to-microSD extensions. 3.5" long
deandzines
Return to Newbie talk
