micro sd to sd card extension
Postby New Passion » 2015-Mar-Sun-12-Mar
Hi,
I have been looking at a way to print without my computer tethered to the printer. I know you can buy the lcd, but I wanted to try the micro sd slot, but it is very inconvenient to get to. I seen an extension cable that plugs into the micro sd slot on the printer and allows you to plug in a standard sd card in the other end. Here is a link to one, there are many more out there. http://www.ebay.com/itm/Micro-SD-Male-t ... 258d54e1cb
Will this work ??
New Passion
Re: micro sd to sd card extension
Postby musk » 2015-Mar-Sun-12-Mar
I've tried one that looked identical to that ebay link, but it didn't work:
http://www.aliexpress.com/snapshot/6192 ... 3589083397
But I've got three of these and they work great:
http://www.aliexpress.com/item/SD-to-TF ... 61833.html
Printrbot Metal Plus (2x)
Printrbot Simple Metal (2x)
musk
Postby New Passion » 2015-Mar-Sun-13-Mar
Thanks musk, I just ordered one.
New Passion
Postby thawkins » 2015-Mar-Sun-13-Mar
New Passion wrote:Hi,
Will this work ??
Without the lcd, i dont think there is anyway to start an sdcard print unless you are tethered.
There is technicaly a mechanism simular to the autorun.inf on marlin, i will dig and get some details.
Postby 2Mylent » 2015-Mar-Sun-17-Mar
Avec métalliques simples Printrbot pour exécution automatique SD Card: le nom de fichier est impérativement "auto0.g"
Source des informations: Printrbot.com
Printrbot Simle Metal + Upgrade Heatbed / Upgrade E3D v6 / Simplify3D / Win7 64bits
http://www.2mylent.fr/Helicos/
FRANCE
2Mylent
Postby New Passion » 2015-Mar-Mon-22-Mar
Is there a certain sd card that you have to use ie. 2 GB or will a 32GB or 64GB work, and do I have to format the card to fat32 or some other format ?? I understand I have to put the file in the root directory and name it auto0.gcode. Thanks for the help.
New Passion
Postby thawkins » 2015-Mar-Tue-01-Mar
New Passion wrote:Is there a certain sd card that you have to use ie. 2 GB or will a 32GB or 64GB work, and do I have to format the card to fat32 or some other format ?? I understand I have to put the file in the root directory and name it auto0.gcode. Thanks for the help.
marlin cant handle sdxc, so its best to stick to 2GB or 4GB cards, fat16 or fat32 are ok.
Note: once the printer has printed auto0.g it starts looking for auto1.g etc etc. So the only way to get it to print auto0.g again is to powercycle it or reset the board and force marlin to reload.
Postby New Passion » 2015-Mar-Tue-11-Mar
Thanks thawkins. When you say reset the board, are you referring to the little black push button on the board, and do I reset it with the power on. I am not sure what you mean when you say powercycle it. If I turned the power supply off after the print finished would this make Marlin reset so I could use auto0.gcode on the next print or would I still have to push the black button to reset the board, if that is the reset switch ( I am assuming it is). Thanks for your patience for a newbie.
New Passion
Postby 2Mylent » 2015-Mar-Tue-12-Mar
New Passion wrote: I could use auto0.gcode
Printrbot say: "auto0.g" not "auto0.gcode"
But i have not tested, my fingers are too big to put on and remove the micro sd card :mrgreen:
FRANCE
2Mylent
Postby orangefurball » 2015-Mar-Tue-17-Mar
I use a 32GB SDXC card in mine, although it's in a microSD > full size SD adapter. Not sure if that makes a difference.
.g and .gcode are the same iirc
Thingybot Delta Printer
http://www.thingybot3d.com
orangefurball
Laser scintillater
Postby New Passion » 2015-Mar-Tue-17-Mar
Thanks orangefurball, I have some sd cards laying around for my digital camera, they vary from 2 GB to 4 GB to 16 GB. I think I will wait until my micro sd to sd extension comes in that I ordered and go from there, but still not sure about the reset of the board after printing that thawkins mentioned earlier.
New Passion
Postby orangefurball » 2015-Mar-Tue-18-Mar
New Passion wrote:Thanks orangefurball, I have some sd cards laying around for my digital camera, they vary from 2 GB to 4 GB to 16 GB. I think I will wait until my micro sd to sd extension comes in that I ordered and go from there, but still not sure about the reset of the board after printing that thawkins mentioned earlier.
Basically what he means is, if you have an "auto0.g" file on your printer and you finish the print, it will not print "auto0.g" again because it will be looking for "auto1.g"
So if you want to print 2 "auto0.g" files, just simply hit the reset button after it is finished. It will then start searching for "auto0.g" again instead of "auto1.g"
The reset button is located here on the Printrboard
orangefurball
Laser scintillater
Postby New Passion » 2015-Mar-Tue-19-Mar
Ok I now I understand. Thanks for all your help
New Passion
Postby deandzines » 2017-Nov-Sat-12-Nov
TEM Products sells them on Tindie. Do a search for "microSD extension cord"
They are small microSD-to-microSD extensions. 3.5" long
deandzines
Return to Newbie talk
