Printrbot Talk Forum • View topic - Posts on Printing Surfaces and Bed Clearance
Postby RetireeJay » 2014-May-Thu-13-May
Some newbies have found it difficult to search for info on printing surfaces, bed alignment, and the like. I have surveyed much of the forum and found these posts that look useful.
Posts regarding printing PLA:
viewtopic.php?f=80&t=11483&p=73427#p73426 - New in July 2017: Several flexible surfaces compared - well worth reading
viewtopic.php?f=74&t=8995 - New in Jan 2015: Blue painter's tape, Lexan, and Carpet Tape
viewtopic.php?f=74&t=9151 - Another survey focusing on blue tape, Lexan, and ConTac, Aluminum, and white painter's tape with room for expansion.
viewtopic.php?f=105&t=4454 - Slightly dated guide to setting up a Simple (uses string actuation and doesn't have zeroing switches.) Does mention painter's tape
viewtopic.php?f=15&t=3352&p=22197 - Troubleshooting problem with inadequate adhesion, both PLA and ABS
viewtopic.php?f=29&t=5912&p=38177 - Bed materials for PLA, and bed cleaning
viewtopic.php?f=16&t=6403 - Hairspray, painter's tape on aluminum, lexan, or glass
viewtopic.php?f=16&t=5268 - Picture of what happens when Z zero is not adjusted correctly and/or there is no adhesion, with recommendations.
viewtopic.php?f=16&t=4633#p30511 - Setting z zero on a Junior
viewtopic.php?f=16&t=6171 - Setting z zero on a Junior (picture showing adjustment screw)
viewtopic.php?f=16&t=5901 - Problem setting z zero on a Simple
viewtopic.php?f=16&t=1948 - Printing PLA with a heated bed; allow it to cool some after the first layer.
viewtopic.php?f=29&t=6769#p46552 - Oracal Oratape HT55 seems to work extremely well
viewtopic.php?f=74&t=8516 - Very specific tapes and process to get good adhesion over large area
Posts regarding printing ABS:
viewtopic.php?f=29&t=453 - Drawcut's big survey post on bed materials and preparation.
viewtopic.php?f=16&t=1381 - Floor wax on glass.
viewtopic.php?f=16&t=1350 - Sugar water on Kapton; also mention of cooling object before removing.
viewtopic.php?f=16&t=593 - Adjusting first pass height to a sheet of paper
viewtopic.php?f=16&t=2026 - Using Kapton or Painter's tape or glass, coated with Aqua Net hair spray, or Future Floor Wax, or PVA (Elmer's glue) thinned with water, or "ABS juice"... and Bounce dryer sheets to prevent ABS from sticking too much!
viewtopic.php?f=16&t=2644 - Discussion of blue tape vs ABS juice vs hairspray
viewtopic.php?f=16&t=3061 - Comparison of aluminum vs glass, and discussion of different types of aluminum
viewtopic.php?f=16&t=2863 - "Formula" for making ABS juice; discussion of why use glass or some base that is very very flat.
viewtopic.php?f=16&t=3421 - Cleaning print bed with acetone - watch out, it can hurt Kapton. Also, mention of glue stick.
viewtopic.php?f=15&t=2525&p=17425 - Discussion of bed temperature, thermistor calibration etc along with Kapton, ABS juice, etc.
Post regarding printing with nylon (actually multi-material):
See Taulman3D's recommendation of Elmer's glue on glass:
  • 2
Re: Posts on Printing Surfaces and Bed Clearance
Postby RetireeJay » 2015-Feb-Wed-20-Feb
New post: viewtopic.php?f=80&t=7400 Ultem (polyetherimide) print surface for both PLA and ABS - claims to be great!
Last bumped by RetireeJay on 2015-Feb-Wed-20-Feb.
Return to Newbie talk
