New users CAN post pictures
Postby RetireeJay » 2014-Apr-Sat-20-Apr
Re: New users CAN post pictures
Postby Killyin » 2014-Nov-Sun-22-Nov
Sometimes a video is worth more than a picture...especially when it includes sound.
I'm being told that my post requesting help is "too spammy" because it includes an off-site URL.
Killyin
Postby RetireeJay » 2014-Nov-Mon-08-Nov
When you absolutely must post an off-site URL, the best way to do it is to break it down
www (dot) youtube (dot) yourvideo
Postby Mooselake » 2014-Nov-Mon-11-Nov
New users CAN post youtube videos:
How to embed youtube videos
The format is pretty specific, so read the friendly manual above for directions. Moose have problems remembering how to post videos, so I use this topic when I need to.
Postby Killyin » 2014-Nov-Mon-21-Nov
No luck, even with the examples in the above post.
Killyin
Postby Mooselake » 2014-Nov-Wed-13-Nov
Post it as youtube dot com etc. and one of us will edit it for you. With that example you should be able to do it in the future.
Here's the unofficial Mooselake anti-spam theme song. Never actually seen a Queen video before. Youtube changes my URLs to https, which won't work; if that happed to you change it to http:.
Postby ThereWillBprints2 » 2015-Apr-Thu-04-Apr
That is super nice of you.
ThereWillBprints2
Return to Newbie talk
