Printrbot Talk Forum • View topic - Calibration cube looks kind of like a frosted mini wheat
Postby habitmelon » 2013-Sep-Fri-12-Sep
We finished assembling our Printrbot Plus v2, all the axes are moving, and we can print a cube (15mm)^3, but I can see the filament (picture attached)
The temperature is 190°C, the bed is 70°C, I am thinking I should heat it up.
Does anyone recognize this 'stringy' effect, is it just not getting hot enough? What parameters should I adjust to get rid of or reduce this?
habitmelon
Re: Calibration cube looks kind of like a frosted mini wheat
Postby DJNOS1978 » 2013-Sep-Fri-12-Sep
Eat it. Sorry but I had to.
DJNOS1978
Postby Tdeagan » 2013-Sep-Fri-14-Sep
Could be a variety of things, the first thing I'd check is the Extruder ESteps value. There are numerous posts and instructions for calibrating the extruder, so I won't repeat them here. But that's essential. Calibrating the X and Y axes may make a difference as well.
The settings in your slicer could be making a difference, what do you have the layer height set to?
One other thing could be that you're missing steps (which could cause the spaghetti at the top,) which might be related to the amps available to each motor. The Printrboard has trim pots for each axis. Have you adjusted them at all? Are the motors running cold or hot?
I've never needed to run my PLA over 185C to get good results, so I wouldn't think you'd need to push past 190C.
It is worth making sure you're getting evenly fed filament, check the hob to make sure it's grooves are clean, if not, clean that up.
Good luck!
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
Quick Change Extruders:
MIC-6 metal bed
Thingiverse Profile:
Tdeagan
Postby habitmelon » 2013-Sep-Fri-17-Sep
Layer height is set to 0.3mm, do you have any recommended tutorials for calibrating the extruder?
habitmelon
Postby mdfast1 » 2013-Sep-Fri-18-Sep
Read the getting started guide then report back . This is most likely an extruder calibration issue. Or not setting the nozzle size/filament diamater correctly in the slicer you are using.
UBIS 13
Printrbot LC+ - Operational
Printrbot Original- Donated
GT2 - 20 Tooth Pulleys
GT2 Belts
Brass Threaded Rods
Spur Gears from drawcut
.35mm nozzle
mdfast1
Postby RetireeJay » 2013-Sep-Fri-20-Sep
It also looks like maybe your Z calibration is off. The layers look so widely separated. Are your z threaded rods the stock 5/16" - 18? If so, your z calibration should be set to something near 2267.72 steps per mm.
What are the dimensions of the finished "cube"?
Return to Newbie talk
Users browsing this forum: Bing [Bot] and 1 guest
