by Tdeagan » 2013-Jul-Fri-22-Jul
I hated everything I tried until I started using . It's a lot easier to learn than it seems at first and you can do real work with only a few lines of code.
Try it, you'll like it!
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
Quick Change Extruders:
MIC-6 metal bed
Thingiverse Profile:
