Printrbot Talk Forum • View topic - Build log - Mochaboy's Printrbot Jr
Postby Mochaboy » 2013-Jul-Fri-16-Jul
Printrbot Jr born 6/13
Brass M8 Threaded Z Rod
Tool less belt tensioners
Aluminum print plate
Mochaboy
Print winner 1st
Print winner 1st
Re: Build log - Mochaboy's Printrbot Jr
Session 1... Base Complete
Mochaboy
Print winner 1st
Print winner 1st
Session 2 - X axis - Bearings and Pelt
Mochaboy
Print winner 1st
Print winner 1st
Session 3 - Sad Panda - Broken limit switch
I just installed the Z coupler and went to grab the limit switch for what I think is the z axis when I noticed the tab had broken off :( These are not hard to find, but according to the instructions - it's not wise to proceed until this part is installed. This is one of those of times when you cast offs you've salvaged from old electronics really come in handy. So I grabbed the aluminum housing from an old floppy drive (!) and used a pair of tin snips to cut off a 4.5mm sliver that would serve as the new lever. It's not perfect, but it will work until I get a proper replacement installed.
With this being the holiday weekend too - who knows when the "next time" will come - need to use as much time as I can during the break :)
Mochaboy
Print winner 1st
Print winner 1st
Postby Mochaboy » 2013-Jul-Sun-14-Jul
Mod list:
Going to do some cable management - researching part #'s and compiling the list here:
Mochaboy
Print winner 1st
Print winner 1st
Postby mrsamnc » 2013-Aug-Thu-12-Aug
Subscribing to catch any updates. :D
mrsamnc
Postby Mochaboy » 2013-Sep-Thu-20-Sep
woohooo1!!!oneone!!!
Mochaboy
Print winner 1st
Print winner 1st
Return to Newbie talk
