by RetireeJay » 2017-Mar-Tue-18-Mar
Well, for starters, the Printrbottalk forum is definitely still active, with about a dozen posts a week. (Not counting spam)
The Moderators and some others use the feature "View recent posts" - and the recent posts show up flagged in red until viewed (regardless of which sub-forum they are in).
However, this forum has never been an "Official" Printrbot forum. For quite a while there was an active sub-forum in "General" that Printrbot monitored, but they pretty much don't look at it anymore. When you come here, you get unofficial volunteer help.
There was a debate a while back about having sub-forums for specific models, but almost all topics of interest span several or all Printrbot models; the fundamentals of FDM printing, stepper motors, resistance heaters, thermistors, etc. are constant, and Printrbot has only used a small handful of different extruders. (Maybe the most recent electronics, the G series replacement for the Printrboard, will deserve its own sub-forum).
To get to your question, if you are using the correct pin (pin 1) on the ICSP connector (and your board doesn't have any flaky faults on it) then in principle there should be no interaction with the USB. Now, maybe there is some electrical noise being generated by your fan that is causing a problem. Just as an experiment, you could try connecting the black lead from your fan directly to one of the black leads coming in on the power connector. That will move the noise off from traces on the board. If you still have a problem after doing that, then perhaps the fan's electrical noise is being "broadcast" and the USB wiring is picking it up like an antenna.
Going back to my ham radio days, the methods for reducing this kind of interference are to twist the wires from the fan together so they are like a DNA helix, and to keep the fan's wire and the USB cable wiring as far apart as possible.
