You might want to give a little more information.
What Simple version is it, what is the bed size?
Has the printer been modified?
The filament size that it will print is determined by what size hot end the printer has.
Normally speaking it will either be 1.75mm or 3.0mm. Pal filament comes in both sizes and is the main type of filament used.
The heated bed and it's power requirements depends on the size of the print area of the printer. Here is just one of many vendors on e-bay you can order from.
http://www.ebay.com/itm/12-X-12-Heatbed ... SwDuJW1dWd
Core XYZ
It's all in the details!
