Hi everyone,
I am setting up an Octoprint server for my Play which I want to run on an Intel Edison using the mini breakout board (see "Powering the Mini-breakout Board" section of for more information on that board, full HW guide is ). I plan on using the J21 7-15V jumper to feed it power as it is needed to enable USB host (for Octoprint). 1A should be enough to power it, from what I read.
Is there a way to use a 12V rail of the Printrboard to power it instead of a separate power supply? I am looking at the but don't know which connection to pick. This would use the stock laptop power brick coming with the printer, I am not running a heated bed.
I have found similar posts on the forum (like ) but this is to power a Raspberry Pi off the 5V rail, which is not what I want (I expect this to be doable using one of the 12V rails since those provide more power than the 5v ones).
Bonus points for the same question, this time for powering an LED to light up the print area.
Thanks for your help,
Vincent
