Printrbot Talk Forum • View topic - looking enclosure for the printrbot metal plus
Postby DGMurdockIII » 2016-Jun-Wed-15-Jun
dose anyone have a way to make or now where to get a enclosure for the printrbot metal plus
DGMurdockIII
Re: looking enclosure for the printrbot metal plus
Postby lairdb » 2016-Jun-Wed-16-Jun
Do you really want to completely enclose it? For temperature stability? Or so it can be looked at but not touched? Or...?
Any competent custom plastics house could build you a clear 5-sided box of the right size, or 4 sides and a door. If you just want to protect it from casual poking, or just to communicate the "don't touch" concept, you could use a clear riser like , on it's side. (I think 16" is wide enough for the full range of side-to-side.)
Simple Metal Kit, heated bed
Mods: blower fan with self-remixed
Usually Cura.
lairdb
Postby DGMurdockIII » 2016-Jun-Wed-19-Jun
temperature stability for ABS printing
DGMurdockIII
Postby Mooselake » 2016-Jun-Thu-14-Jun
8020, Misumi, or similar aluminum extrusion (maybe the 10mm open stuff), plus 6mm birch plywood, and an appropriate sized piece of plexi or acrylic from the big box store. You should be able to whip one off pretty quick.
Postby rswarner » 2017-Jul-Tue-13-Jul
I'm interested in this too. I'll see about designing an acrylic thing, closed with hinges and magnets and report back here...
Sent from my iPhone using Tapatalk
Printrbot+
Y platform mods
Aluminum faced 1/2" EPS insulation under print bed
GT2 pulleys and belts
This filament guide thing: http://www.thingiverse.com/thing:35799
rswarner
Return to Newbie talk
