Printrbot Talk Forum • View topic - ESD
ESD
ESD
Postby davegun » 2015-Jan-Thu-22-Jan
My Z Probe when out on my Simple 1405 (wood). I looks like the MOSFET on printrboad Z Stop has failed. I have been in contact with printrbot support and it looks like they are sending me a replacement board. Today I put an ohm meter on the power ground and I am not seeing any connection between ground and the z-probe threaded case, or the case of the stepper motors. I'm wondering if a static discharge to the Z probe, or stepper motors could take out something on the printrboard?
Since the 1405 is all wood, there is no grounding though the case, I'm thinking about adding some ground wires to all the metal parts to give any static discharge a path to ground (not thought the electronics). Has anyone else experienced this, or has tried grounding?
Thanks,
Dave
davegun
ESD
Re: ESD
Postby thawkins » 2015-Jan-Thu-23-Jan
Re: ESD
Postby thawkins » 2015-Jan-Fri-00-Jan
Re: ESD
Postby davegun » 2015-Jan-Fri-03-Jan
Yes, I have the Rev F4 board. I'm not sure what caused this, it worked well for about a week, then the Z-stop quit working.
I live in the northern US and it's been quite cold. My furnace has been running steady for the past several days and the humidity is low. It's easy to build up some static in these conditions.
Thanks,
Dave
davegun
Re: ESD
Postby thawkins » 2015-Jan-Fri-04-Jan
Re: ESD
Postby RetireeJay » 2015-Jan-Fri-11-Jan
As an Electronics Engineer, I would call the use of a MOSFET with a naked gate connected to the outside world a design flaw for sure. For the optimum protection of the MOSFET, there should be a resistor to ground (or to +5V, depending on the nature of the external circuit driving it), and this resistor should have a relatively low value, like 4.7K.
Re: ESD
Postby davegun » 2015-Jan-Fri-22-Jan
davegun
Re: ESD
Postby thawkins » 2015-Jan-Fri-22-Jan
Re: ESD
Postby RetireeJay » 2015-Jan-Sat-08-Jan
+1 on thawkins.
I don't have a probe, and I don't know the exact specs of its output. The selection of resistors is totally dependent on the complete circuit. So he's right, my suggested 4.7k isn't going to work.
I didn't realize there was a voltage discrepancy where the probe puts out 12V in the high state. Ouch. I guess the MOSFET has at least a 12V rating on its gate...
As to using a diode in series with the signal lead (and I assume no MOSFET buffer), it would be worth checking the definition of a logic LOW at the input of the MCU. Back in the TTL days, logic LOW was 0.4V, and you can't get there if you have a 0.6V diode in series with your "ground." But maybe nowadays logic LOW is defined as some other voltage south of 2.5V (there's always a "forbidden zone" between a clean logic LOW and a clean logic HIGH).
Re: ESD
Postby thawkins » 2015-Jan-Sat-08-Jan
Re: ESD
Postby davegun » 2015-Jan-Sat-21-Jan
I looked up the part number on the probe, it LJ12A3-4-Z/BY. It's a PNP, 6-36VDC 4mm Detecting Distance NO Inductive Proximity Switch. I also tested my probe and the LED works correctly, but the output with a 12V supply is 6V, and when triggered is 4V, so I think this is also bad. They were $5 on Amazon so I ordered two.
I like the diode with no MOSFET, if I were not getting a replacement board, this looks like the best solution I have seen. The MOSFET could be removed from the board, or I could reassign an open pin from the Extension Pin Header. I would need to re-compile and flash the board. I have poked around in the source code and found how to change the pin numbers, but I don't think I'm quite ready to go there just yet.
I can print just fine with a level bed, and no Z stop. To be honest, I have made the best prints since the Z Probe went out. I have only been printing for a few weeks, so that may not be saying much:) I think for now, if Printrbot follows through and replaces my board, I will run it stock, but with added grounding. Grounding the probe case to give any static discharge a path to ground, and a choke on the Z Probe wires to discourage any static discharge (or induced current) from traveling down the probe wires can't hurt. If the MOSFET get's taken out again, I will make it work another way.
Thanks for all the discussion, this has been interesting and information I can use!
Dave
davegun
Re: ESD
Postby Hopbot » 2015-Jan-Sun-00-Jan
Dave,
Just so you know you are not alone with the blown MOSFET. I like the idea of adding grounding wires, I could work on adding them while my new board in coming. I haven't got to print anything yet, the PB guys wanted me to send in my board before they sent out a new one. I also ordered a couple new proxes for the Z stop, it is amazing that they ship two of those from China on a plane for $10 somebody is losing money on that deal for sure.
Thanks to all for the information from me too!
Chris
Hopbot
Re: ESD
Postby thawkins » 2015-Jan-Sun-01-Jan
Re: ESD
Re: ESD
Postby davegun » 2015-Jan-Sun-18-Jan
Reason: Fixed quote typo for you :)
davegun
Re: ESD
Postby davegun » 2015-Jan-Sun-19-Jan
davegun
Re: ESD
Postby lwalkera » 2015-Jan-Mon-13-Jan
Yeah, it's an issue. Brook wanted something quick to use 12V on the probe towards the end of the Rev F dev cycle, since some of the probes they were getting didn't work correctly on 5V. So I just used the same FET as the fan output since it was already on the BoM. Live and learn I guess.
On new boards, I told them to switch to MMUN2211LT3GOSTR-ND which is a pre-biased NPN BJT. It shouldn't be as sensitive to ESD, and is a drop in replacement if you'd like to repair your board.
Laine Walker-Avina
lwalkera
Re: ESD
Postby davegun » 2015-Jan-Mon-20-Jan
davegun
Re: ESD
Postby lwalkera » 2015-Jan-Mon-22-Jan
Yeah, those are the same part, just different packaging. I bought a strip of 100 myself for testing and rework because they were so cheap. Also, if you're in the US, make sure you use the First Class Mail as the shipping option. I got mine delivered (in CA) about 2 days after it left the warehouse (from MN).
Laine Walker-Avina
lwalkera
Re: ESD
Postby davegun » 2015-Jan-Tue-22-Jan
Laine,
Great info, thanks. I think I will order some.
Dave
davegun
Re: ESD
Postby davegun » 2015-Jan-Thu-23-Jan
Update, Today my two Z Probes came in the mail, my MOSFETs from Digikey came in the mail, and Printrbot sent me a message that my replacement board is in the mail! I should have this problem covered.
Dave
davegun
Re: ESD
Postby davegun » 2015-Jan-Sun-23-Jan
Final Update: My replacement printrboard came this weekend. When replacing the board, I installed a new Z Probe. I looped the three sensor wires once through a ferrite toroid. I soldered a ground wire on one of the lock washers and used this to ground the probe. I looped the ground wire around case bolt of the extruder stepper and ran the ground in the spiral wrap. I ground the y stepper, and the z stepper on the way. The ground wire is terminated at the power supply ground. I also added a jumper with resistors in line with the Z Probe.
Everything now works as it should. I don't plan to test this by touching it after running across the carpet in wool socks, so all this extra voodoo may not do much, but it makes me feel better :)
Thanks everyone for your comments. I'm new and don't know who's who, but I couldn't help noticing Laine Walkers name on the printrboard... small world!
Thanks,
Dave
davegun
Re: ESD
Postby JonS » 2015-Apr-Sat-14-Apr
My z probe has failed. The wiring was flaky, so the probe was failing on the right side of the bed. I spliced in some replacement wires, but now it's completely dead. So I wonder if my FET has blown too, or if my manipulation of the cable has opened up another break somewhere.
I have a new probe on its way, so I'll find out soon. I guess I should order some FETs just in case.
I see they're made by ON Semiconductor, my company. Not that that really helps me. I work for the CMOS image sensor division.
Printrbot Metal Plus with:
- Dual Gear Head extruders
- Heated bed
- PEI print bed film
JonS
Re: ESD
Postby RetireeJay » 2015-Apr-Sat-14-Apr
The FET was a mistake to begin with. Laine Walker-Avina (lwalkera) designed the board, and he's admitted as much. He also has a redesign used in boards Rev F5 and above using a bipolar transistor with built-in biasing and protection resistors. It's a physical drop-in replacement for the FET. viewtopic.php?f=15&t=8929&p=57547&hilit=bjt#p57547
So don't go buying replacement FET's; buy the bipolar one instead.
Re: ESD
Postby JonS » 2015-Apr-Sat-20-Apr
Thanks Jay. That's what I've bought.
Yes, it was a mistake to use an unprotected FET. I know ON Semiconductor has a whole load of ESD protection parts in its portfolio. Maybe I can put lwalkera in touch with one of our Solution Engineering Centers. I'd love to see us doing something for 3D printers, and we have a lot of parts in our portfolio (including stepper motor drivers) that are a fit.
- Heated bed
JonS
Re: ESD
Postby scotthraban » 2019-Jan-Tue-13-Jan
I know this is a really old post, but hoping those in the know can still help. I am pretty sure that the fet on my board is fried. I am getting the "up, then up some more when homing Z", always triggered according to M119, but light only comes on when near the bed / metal. I see the voltage change along with the sensor light when measured at the board Z stop connector, so pretty sure it is not the sensor, but have one on order anyway, since that is the easy fix.
I also have some of the bipolar ... transistors identified above on order for when changing the sensor does not work ;). That is where I need help, does anyone have a picture or description of where the original fet is on the F4 board? I see a component just off the corner of the Z stop connector that looks to be the right form factor, but it is not labeled that I can see ...
Thanks in advance,
scotthraban
Re: ESD
Postby RetireeJay » 2019-Jan-Tue-14-Jan
Yes, there is a 3-terminal device, Q4, immediately adjacent to the Z probe connector; that's the "MOSFET" or input transistor for sense level translation.
Re: ESD
Postby scotthraban » 2019-Jan-Sat-15-Jan
Thanks @RetireeJay, I also found the schematic of the board, and proved to myself with a multimeter that I had idetified the right component.
First time doing any SMD soldering, so I tried to practice on an old dead board, but I think the board may have been too old and didn't have lead free solder, since it was much easier to remove components than from the F4 board, and unfortunately I ended up lifting a pad. As a silver lining, the pad I lifted was for the sensor trace, so I was able to do a wire patch from the connector to the leg of the transistor, bypassing the trace.
So my board now looks like ... crap ..., but it WORKS! Thanks so much to everyone on this thread, you get extra karma points today!
--Scott
scotthraban
