Printrbot Talk Forum • View topic - Master calibration post/list?
Postby allanonmage » 2014-Aug-Sat-23-Aug
I finally got around to tinkering with my Printerbot LC again. I upgraded the Y rods from Lowe's specials to ones rated for 3D printers and now the Y axis wobbles a LOT less if I move it back and forth. Against good technician practices, I also changed out the X axis belt to the GT2 belt I had purchased a while back at the same time.
I remember doing the calibration, and tried to search the forums for the calibration guides, and was not able to find stickies or effectively able to use the search. Eventually I found one in the **software** section. I guess it's a software thing, but my first thought is that calibration is a hardware thing, so I was going crazy looking there. Can we get a global sticky with a calibration guide and links to other calibration related posts?
*edit* As I am searching for those posts, I'm updating this one to be that sticky, so it will be a good start.
Printrbot X Y Z axis and extruder [sic] calibration
Postby plexus » 15 Jan 2013 23:11
viewtopic.php?f=29&t=2189
Calibration Constants Tutorial
by RetireeJay » 13 Mar 2013 14:13
viewtopic.php?f=18&t=2763
Useful links (will expand at a later date)
Printer Calibration Gets messed up when power down??
viewtopic.php?f=29&t=6750&hilit=calibration
How to Calibrate your Printer
http://help.printrbot.com/Guide/How+to+ ... Printer/81
Search Results
http://help.printrbot.com/Guide/search/ ... alibration
Extruder Calibration
http://www.printrbottalk.com/wiki/index ... alibration
Tags:
calibrate, calibration, m92, m500, x, y, z, axis, calculate
Here's a visual of my current setup:
allanonmage
Layer 100 of 1234
Re: Master calibration post/list?
Postby RetireeJay » 2014-Aug-Sun-09-Aug
I made this topic "sticky" for you.
RJ
Postby Mooselake » 2014-Aug-Sun-11-Aug
How many tooth pulley?
Given the pulley tooth count you can determine the diameter of the pulley, the circumference, and then the amount it moves for each microstep - usually 3200 steps/revolution. I googled "gt2 reprap calibration" and found . For the very popular 20T pulley (which may not be the one you have), and the stock 16x microstepping/200 step per rev motor it works out to 80 steps/mm.
Calculated values for standard sized pulleys are always more accurate than the print/measure technique. If you find that your printed size is off most likely you'll need to calibrate your extruder and extrusion width better, not fiddle with the steps/mm.
Extruder calibration, as TutherJay might say, is a different container of squirmy critters. There's too many variables to calculate more than a starting point, and accurate calibration will rely on measuring, extruding, and measuring, possibly followed by tweaking things like the extruder multiplier. Here in the moosecave I've determined a "good enough" steps/mm value, and usually tweak the filament size to get an accurate width.
Postby allanonmage » 2014-Aug-Mon-13-Aug
allanonmage
Layer 100 of 1234
Postby thawkins » 2014-Sep-Thu-07-Sep
Postby Mooselake » 2014-Sep-Thu-07-Sep
Bites the dust.
I'm starting to believe that end of quota period in Pakistan thing.
Postby Sigmoid » 2014-Nov-Mon-22-Nov
Sigmoid
