by Tdeagan » 2013-Jul-Tue-17-Jul
If multiple machines and USB cables have all declined to connect, you're narrowing it down to the Printrboard. Just as a last review, do you feel really good about all the power connectors (and other connectors for than matter,) on the Printrboard? Is the ATX jumper correctly in place (you mention getting the board green LED, but it doesn't hurt to check.)
You could also make sure you have good USB Serial drivers, you can download them at
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
Quick Change Extruders:
MIC-6 metal bed
Thingiverse Profile:
