Printrbot Talk Forum • View topic - Printrbot connects to pc but will only goto home position
Postby jdaggie13 » 2013-Jun-Sun-13-Jun
I recently assembled a Printrbot Jr. and was able to connect to Repetier, and when I tried to manually control the bot it gave me the error, Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting).
But when I send the bot home it will return home so I know the axes motors are working.
I tried Pronterface and had the same problems.
Also the extruder won't heat up or read temperatures.
And where can I buy a cable to connect my fan to the board?
Thanks in advance
jdaggie13
Postby Mooselake » 2013-Jun-Sun-19-Jun
In Repetier-host you should be able to check the log (drag the top of the logging area up if it's not visible.) For displayed errors.
You should be able to find a fan extension cable at many computer stores; I got one from Amazon. A 2 wire cable is best, but a 3 site will work fine - just let the extra pin hang off the side, and make sure you use the same two sides on both ends.
Re: Printrbot connects to pc but will only goto home positio
Postby Tdeagan » 2013-Aug-Sat-17-Aug
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
Quick Change Extruders:
MIC-6 metal bed
Thingiverse Profile:
Tdeagan
Postby Tdeagan » 2013-Sep-Sun-13-Sep
Though I'm not exactly sure which part fixed this, I got it working and talked about the details in this thread:
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
MIC-6 metal bed
Tdeagan
