Printrbot Talk Forum • View topic - Lemon/Football circles fixed!
Postby Tdeagan » 2013-Mar-Wed-15-Mar
I'd been having a lot of trouble with circles all printing on my Printrbot Plus with corners, the term 'lemon' and 'football' circles are used by folks with similar problems. This appeared to be an X backlash problem since it seemed that the system was lagging when adding X vector to the Y motion.
My X-Axis belt was really tight, so it wasn't obvious backlash. However, based on the PB+ assembly instructions step 142 (sorry, system won't let me post an offsite link) , the bolt connecting 220 to 232 had a nut on the OUTSIDE. The belt was actually pulling the motor mounting frame out of square. It was positively trapezoidal! This was causing the gear on the motor shaft to rub against the x-axis main frame.
I took it apart and put the nut on the INSIDE of 232 (see picture below). This serves as a more effective stand-off than the wooden peg and let me true-up the mount. The belt tension holds the motor against the frame, but I'll add another nut on the OUTSIDE for insurance.
Now the system is printing GREAT!! You can see the difference in the (mr. blurrycam) calibration circle before and after:
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
Quick Change Extruders:
MIC-6 metal bed
Thingiverse Profile:
Tdeagan
Re: Lemon/Football circles fixed!
Postby holmes4 » 2013-Mar-Wed-16-Mar
Very interesting. I had noticed that the mount isn't the most stable thing in the world, though on my PB it doesn't seem to be a problem. I have added extra nuts for stability in other places, though.
Steve
PB+ Backer 1402
holmes4
Bowden extruder
